How to replace door speaker cover?
Old Jun 16, 2008 | 03:29 PM
tom2112's Avatar
She can ride with me ;)
Default How to replace door speaker cover?
OK, my driver's side door speaker cover was cracked, so I ordered a replacement. Now I can't get the cracked on off. I thought it would pop right out. Any suggestions?
Edit:
Well, I finally got the speaker cover off. Thankfully I had a interior trim panel tool, like this one:
http://www.crutchfield.com/App/Produ...h=tools&tp=990
It is well worth the money ($4.50) as it won't scratch your interior panels or parts. It slides easily between the cracks and usually the trim peice will pop out as you slide the tool under. If not a little gentle prying will opo the trim peice off. The tip of the tool gets chewed up, but that's because it is soft and won't harm your trim.
Here's a step by step for those interested in removing the speaker cover:
You don't need to remove the whole door panel!
1) open the car door wide so you have lots of room to work
2) slide the tip of the trim panel tool between the inside edge of the silver ring that surrounds the speaker cover, and the mesh of the speaker cover. It won't go in far only a couple milimeters.
3) work the trim panel tool around the entire circumference of the silver ring, sliding it, and occasionally prying gently out.
4) the silver ring will pop out after a few times around with the trim tool. the watch word here is patience, since you don't want to break off any of the little clasps that hold it in place.
5) once the silver ring is removed, you'll be able to clearly see the around the edge of the mesh speaker cover, and you can see each of the clasps holding it in place
6) with the tip of the trim panel tool, press each clasp towards the center of the speaker and pull the mesh out a little, releasing the clasp. repeat that for each clasp - I think there's 4, maybe 5.
7) Now that the old one's are out, you can easily pop the new speaker mesh back into place. It only fits one way - where all of the clasps line up with the holes in the panel. So you can really screw it up. Just don't force it. If you have to force it, you don't have it lined up right, and might have it upside-down.
8) after the mesh is in place, pop the silver ring back in place. The silver ring has a slight curvature on one side, which follows the door panel's curve toward the front of the car. Put the curve towards the front and it will snap right in. If it doesn't snap right in, you've probablt got it backwards, turn it 180 degrees and snap it in.
Sorry, no pictures of the repair. My camera battery was dead.
Old Jun 16, 2008 | 04:37 PM
Kurts's Avatar
Default Re: How to replace door speaker cover?
It should!
The speaker grills are held in place 4 four clips (for lack of a better description). You should be able to stick something behind them & pop them off. The 'clips' are at the 10, 2, 4 & 8 positions. Try something plastic & reasonably stiff, get it behind the cover & see if a little 'leaning' doesn't work.
Wierd, in the '04 Coupe I had one pop off all by itself.
Good luck, Tom!!
Old Jun 16, 2008 | 05:02 PM
tom2112's Avatar
Does the silver ring around it need to come off too?
Old Jun 16, 2008 | 06:12 PM
nox1s's Avatar
Yes, it does.
Old Jun 16, 2008 | 07:25 PM
tylerxfire's Avatar
so your saying the door does not need to come apart to replace speakers?
Old Jun 16, 2008 | 07:47 PM
nox1s's Avatar
No, to take off the speakers you need to take the door apart (which isn't hard at all)
To take the grill off, you don't need to take apart the door panel.
Old Jun 16, 2008 | 08:45 PM
tylerxfire's Avatar
how do i get the door apart
Old Jun 16, 2008 | 10:02 PM
nox1s's Avatar
Search for the crutchfield master sheet.. explains it perfect.
Old Jun 17, 2008 | 04:50 PM
Kurts's Avatar
Did you get that baby popped-off OK, Tom?
Old Jun 17, 2008 | 05:13 PM
tom2112's Avatar
Nope. I got the car all washed and waxed up, and we've had off and on rain since. So it's staying in the garage for now. I'll hit it again when the sun comes back out.
Old Jun 17, 2008 | 09:14 PM
SRT6nTulsa's Avatar
1. Remove sliver handle cover piece and tweeter grill/trim.
2. There are 2 screws inside the silver handle, one behind the SRS badge, and one between the tweeter and the handle. Remove them carefully, mine were holding a little tension on them
2. Lift up on the door panel, and mind the lock plunger.
3. Corner triangle piece pulls out without screws.
I'm sure I'm forgetting something, it's been a month since I put mine back together.
Old Jun 18, 2008 | 02:17 PM
tom2112's Avatar
Thanks Tulsa! I'll give that a try this weekend.
Old Jun 19, 2008 | 10:54 AM
tom2112's Avatar
I had the day off, so I decided to tackle the speaker cover. I dug up my trim panel tools, and went to work. It was no problem with the right tools. I didn't need a screw driver, nor did I need to take the whole door panel off. I just had to take the silver ring surrounding the speaker mesh off. That was easy once I figured out to slide the trim tool between the ring and speaker mesh from the INSIDE of the ring, not the outside. Pop, pop, and it was off. Another pop or two and the mesh was off. Easy peasy.
Old Jun 19, 2008 | 12:08 PM
nox1s's Avatar
You're missing quite a few screws
To take apart the door panel, read the crutchfield master sheet. It's posted here on the forums somewhere.. do a search.
Old Jun 19, 2008 | 02:20 PM
Kurts's Avatar
Always a snap with the right tools!
Glad you got it squared away, Tom!!
RED DOG
May 4, 2019 08:05 AM
Hoppy
Dec 7, 2018 07:36 AM
reiji
Oct 15, 2015 10:50 PM
michaelcycle58
Jul 28, 2015 08:12 PM
55chevy
Jul 20, 2015 03:08 PM
