For those who've changed their shift knob...
Old Jul 26, 2008 | 09:54 PM
Mike-in-Orange's Avatar
Default For those who've changed their shift ****...
... how do you get the bloody **** off the boot? Getting the boot off the console is easy enough, and the lock ring keeping the **** on is simple as well. But now I've got the ****/boot assembly out of the car and I can't separate these two parts. What's the secret?
Old Jul 27, 2008 | 06:05 AM
joseph m herroscheck's Avatar
Cool Re: For those who've changed their shift ****..
pull hard !
Old Jul 27, 2008 | 09:36 AM
Default Re: For those who've changed their shift ****..
Originally Posted by joseph m herroscheck
pull hard !
I thought that was just to get the **** off the shift lever, which I've done. Pulling hard on the **** to detach it from the boot appears to be very hard on the boot itself. You sure about this?
Old Jul 27, 2008 | 10:02 AM
Crossfireone's Avatar
Hi Mike
Be a little careful with the boot being semi frozen to the ****. Use a hair dryer on the (lowest) setting. Hold it a couple of inches away from the top of the boot & work it around the entire boot slowly. It should become supple enough to gently pry it off the **** without to much force. If not apply a 2nd or 3rd round of heat, again not overdoing too much in one spot & stop & check if any progress is made. Good luck.
Crossfireone
Old Jul 28, 2008 | 07:26 AM
I had some time to take a closer look at the pieces yesterday. There is a press fit collar with two slots in it that pinches the boot between it and the base of the ****. The **** has two tabs that fit through holes in the top of the boot itself and then through corresponding holes in the collar.
With the boot turned inside out and pulled up over the **** I took a thin screwdriver and pryed the collar off, releasing the boot.
I would strongly suggest to others that you NOT just pull hard! to get the boot off the ****.
Old Jul 28, 2008 | 07:31 AM
Mike, I assume this is for a stick ****?
Old Jul 28, 2008 | 12:31 PM
Right you are sir - the automatic doesn't have a boot. I'll get some pix showing the bits and pieces in detail soon.
Old Jul 28, 2008 | 09:17 PM
MAYAman's Avatar
Weird, I just loosened the base screw thingy and gave a little pull and it came right off.
Old Jul 30, 2008 | 11:02 AM
Pictures!
Once the leather boot is pulled up and the collar unscrewed then whole assembly comes out (this is the boot turned inside out, of course):
Remove the locking collar completely and you see another collar with two tabs through it and the leather, holding the boot to the shifter. Trying to just pull the boot off the **** at this point was stretching the leather around the holes and I didn't want to just keep pulling for fear of damaging the boot. Here is is pryed up on one side:
With the retaining collar pryed off you can clearly see the tabs protruding through the leather of the boot:
One of the pre-cut holes in the leather for the tabs to fit through:
Crap, only 4 images per post!!
Finally, the bare **** with the locking collar back in place, sans leather boot of course. Here you can see the pins on the base of the **** and better understand how the top of the leather is then pinched between the base of the **** and the locking collar. These did not want to separate simply by pulling firmly on the **** - that's when the leather was coming under abuse I wasn't willing to give it.
So now it's off and I can get my custom shift boot made up to match my two tone leather interior, complete with light grey stitching!
Old Dec 16, 2008 | 09:20 AM
Buran's Avatar
Look like I am screwed. Upon taking the shifter off. I am missing the locking collar of this assembly. It appears mine has been messed around with by previous owner. So I have no idea how I am going to get my Momo **** on. Or am I missing a part that came with the ****?
Old Dec 16, 2008 | 04:04 PM
How does your factory **** stay on without the locking collar?
Old Dec 16, 2008 | 05:42 PM
danimal's Avatar
That locking collar does not fit the MoMo ****. I've tried using a wire tie to keep the boot up on the ****, but after a few shifts it slides down. I'm not real happy about it, but I'm still trying to figure out some way to keep the boot snug up on the ****. If I can't, then it was money thrown away and I'll have to go back to the original ****.
Anyone have any suggestions?
Old Dec 16, 2008 | 07:26 PM
Buran's Avatar
The bottom part still screws onto the base. It keeps the boot tight on the ****.
Old Dec 16, 2008 | 07:27 PM
Buran's Avatar
I didn't think that it would. I was always under the impression that this was a simple swap out. How is everyone else installing their shift *****??
Old Dec 16, 2008 | 09:41 PM
downwardspiral's Avatar
haha I was just going to ask everyone.. I might order a different boot to save the hassle
Old Dec 17, 2008 | 12:39 PM
Tazz's Avatar
Default Re: For those who've changed their shift ****...
On my custom grey leather boot (do a search on the forum for the company that makes them) i just used a zip tie around the top of the boot inside (pull the boot up over the shift ****, zip tie the boot just a quarter inch or so above the end, then pull it back down). Been good for months now......
Old Dec 17, 2008 | 01:40 PM
SteveS's Avatar
I'd like to ask what may strike some of you as a dumb question ... I understand most of the 'mods' that I see talked about here ... many are things I feel no need to do, but I understand why others would ... I don't understand the reason to replace the shift **** ....
Why do so many want to make this mod ???
Old Dec 17, 2008 | 01:47 PM
I guess it's like any other visual mod, really - just to give the car some "personal" touch. Some people don't like the feel of the factory **** and would prefer leather either in part or in whole.
Me, I just took some Aero Blue touch up paint and a very fine artists brush and painted the recessed numbers and extended "H" pattern in the stock ****. I like all the matching silver trim on the car as is. One thing I did change, however, was the shift boot - hence my reason for this post in the first place. Instead of the plain black boot, I now have a two tone boot that perfectly matches my two tone seats. Unfortunately, this image doesn't show the blue in the numbers, but my shift boot is the hotness.
Old Dec 17, 2008 | 02:09 PM
I like the OEM **** myself too. I thought it was very clever how they continued the roof ridge through the AutoStick ****.
