For those who've changed their shift knob...
on
Re: For those who've changed their shift ****...
Originally Posted by SteveS
I'd like to ask what may strike some of you as a dumb question ... I understand most of the 'mods' that I see talked about here ... many are things I feel no need to do, but I understand why others would ... I don't understand the reason to replace the shift **** ....
Why do so many want to make this mod ???
I like the OEM **** myself too. I thought it was very clever how they continued the roof ridge through the AutoStick ****.
Right you are sir - the automatic doesn't have a boot. I'll get some pix showing the bits and pieces in detail soon.
went to "short" Momo anatomic for two reasons: lower, better fit for my hand, and most of all it is COOL. No, really, here in Phoenix the metal shift **** would brand the shift pattern on your hand if you had the sun hitting it in the summer !!!
danimal,
I bought the momo shift **** that TVT Designs sells and it has a threaded portion at the bottom of the ****. So with this one I can just get a nut and thread it up to hold the boot in place. The thing I find is with the momo **** I have, the boot just sits up nice without the need for even a zip tie.
on
Originally Posted by brianm929
danimal,
danimal,
Most MOMO ***** will just slide over the shaft, and be be held in place by the proper size plastic insert (usually three different sizes are included, pick the one that fits over the shaft snugly) and the three set screws around the bottom edge of the ****. I always use a little loctite on the screws to be safe.....
on
After doing the searching is this the kit that is supposed to come with the ****?
http://cgi.ebay.com/ebaymotors/MOMO-...QQcmdZViewItem
What i don't understand is how do the screws hold the **** onto the shaft? Is thier somethat they screw into on the shaft? What I am asking is when pull the **** up to put my car into reverse will these screws actually keep the **** from coming off in my hand?
Thanks for the help you have given so far.
on
i put a 6 speed boot over my automatic shifter https://www.crossfireforum.org/forum...ad.php?t=28870
Originally Posted by Buran
OK well my problem is this: All I received in my box was the ****. No hardware at all. Didn't know anything else was supposed to come with it. No wonder I couldn't figure this out. SO now wtf am I supposed to do?
Originally Posted by danimal
Check the box again. Mine had all the miscellaneous stuff stuck in a little compartment in the bottom of the cardboard insert. I almost missed it myself.
I received my install kit yesterday and installed it around 1 am since I couldn't sleep. Using only the rubber piece that had the smallest opening, I drilled a small hole in the top of it and pushed it inside the ****. It then took more pressure than I expected to press the **** all the way to the bottom of the shaft.
I do see now what you mean about this **** staying put. Even without the screws, the shaft is so tight going through the rubber piece that its quite a feat to pull it off. As for the screws I used one set and put them in as far as I could then used the second set right behind them in the same hole. The second set sits out slightly but they will make it harder for the screws to come out.
As for the boot I simply used a ty wrap around the very top. The screws sticking out make for a good place to run the ty wrap around since the boot catches on them it doesn't appear like it will slide down. What I may end up doing is finding a slimmer ty wrap and run it around the **** just above the screws. This would give it a slighty slimmer look and the boot would never fall down past the screws.
I don't know if this how every one else did theirs but this way worked for me.
Those MOMO shift ***** are the best, i had the very first one installed, and i just ziptied the boot on used the plastic piece to fasten down the **** to the shaft.
Its in my opinion the best aftermarket **** out there for the Xfire.
Justin
Justin
Where did you get the shift ****? Do you have a link or a SKU number? My XF has an 'airmetal' Momo shifter, and though it fits the car, I tend to like to rest my hand on the shifter when I drive and that gets to be uncomfortable, plus the south TX heat could mean that I could end up with an odd brand on my palm.
I finally took some pictures, still didn't get the new boot though.
