window switch problem
Old Mar 31, 2009 | 06:20 AM
marilynshere@hotmail.com's Avatar
Default window switch problem
The power window switch fell inside the console. How do I get to it to replace it if it is broken or how do I reconnect it to the console is it isn't broken
Old Mar 31, 2009 | 06:03 PM
danimal's Avatar
Default Re: window switch problem
I posted instructions here on how to remove the center console:
https://www.crossfireforum.org/forum...onsole+removal
You may be able to reach the switch by just removing the trim around the shift lever. If not, follow the instructions in post #4 from the above thread and you most likely can reach them from behind and under the front section.
Old Apr 1, 2009 | 07:47 AM
Red face Re: window switch problem
Thank you sooooo much! Its back working again!
Old Apr 1, 2009 | 08:07 AM
danimal's Avatar
You are welcome...glad you have it back as it should be.
Old Sep 13, 2009 | 12:40 PM
ghostface157's Avatar
hey danimal, for those intructions in the pdf you posted, would that be the same for a manual car? would i just take the boot off the stick? thanks in advance.
Old Sep 13, 2009 | 12:47 PM
toughguy25's Avatar
Mine does the same thing on the driver side. The switch still works fine but if I push it too hard it will fall through the console.
PNA
Nov 12, 2020 04:44 PM
KDW4Him
Jul 31, 2015 10:21 AM
gtjl
17
Jul 22, 2015 06:28 PM
55chevy
Jul 20, 2015 03:08 PM
66L72M21
Jul 15, 2015 04:23 PM
