Blower Resistor Resistor - where to get it !
Old Jun 23, 2011 | 07:58 PM
Primeaux's Avatar
Default Re: Blower Resistor Resistor - where to get it !
ARG!!!!! The connector that has the three connections on it has come apart. I dont know what order they go in. ANY HELP???
Old Jun 23, 2011 | 08:52 PM
Primeaux's Avatar
Think I just blew a fuse. Spark! Now nothing! There's no burnt smell so I don't think I fried it. Problem is idk where the fuse is.
Old Jun 23, 2011 | 09:44 PM
Primeaux's Avatar
Also, anyone know which fuse would be for the BM?
Old Jun 23, 2011 | 11:00 PM
#37- 5 amp - circulating air.
Old Jul 12, 2011 | 11:28 AM
X-fired's Avatar
I replaced my fan blower controller (resistor block) with a Mercedes part I found on ebay: "2108206210 SLK320 CLK430 CLK55 SLK55".
It looks identical but the fan speeds for each setting are much higher than before (I wonder if Chrysler has different internal resistor values). The new Low setting is similar to the No. 3 or 4 setting from before. It's way too high for a low setting. I might put a resistor in series to bring the entire thing down. Need to determine what value to use. Bummer.
But, the fan is no longer intermittent.
Old Jul 12, 2011 | 11:54 AM
I replaced mine about a month back with one I bought off eBay. My fans speeds seemed somewhat slower than factory settings. I do know that there are several versions of this blower motor resistor. Seems (to me) that getting the exact one originally installed in our XFires is an issue.
Later,
Old Jul 12, 2011 | 06:14 PM
Primeaux's Avatar
Later,
Same here but I can def handle it for $350 bucks cheaper.
Old Jul 22, 2011 | 06:04 PM
chrisdebo's Avatar
Thanks for the info, guys. My XF's fan is also erratic. I hope it holds on for a little longer.
Old Apr 23, 2012 | 05:24 PM
mspost's Avatar
HI all,
I just got my Roadster 2 days ago, the heater/ac fan wouldn't work.
The little light on the end of the fan speed indicator wouldn't even light up.
Dummy me, since the fan didn't turn on, I forgot about it and left the fan turned to level 4.
About 10 minutes later I smelled an electrical burning smell, had to pull off the road
as there was white smoke coming out of the fresh air intake below the windshield
and smoke was filling the passenger cabin.
I figured out that the heater blower was the problem, have followed this thread to learn how to fix it,
removed the Blower Resister and will remove the Blower Motor and fan next.
My question is:
I know that the Blower Motor is bad, as I see black melted stuff on the motor,
but how do I know if I need the Blower Resister too?
Thanks,
~Karmen in Minneapolis
Old Apr 23, 2012 | 06:54 PM
X-fired's Avatar
If you're certain the blower motor is bad, I would simply replace that and then see if it works. If not, I'd move on to the blower motor resistor.
Old Apr 27, 2012 | 07:13 PM
mspost's Avatar
Turns out I needed the resistor/regulator also,
found it at:
Your Parts Search Returned 1 Part(s)
for $66, or the Behr part for much more, take your pick!
~Karmen in Minnesota
Old Sep 21, 2012 | 07:03 PM
smokey847's Avatar
I was driving today and turned on the AC and fan, there was a horrible burning smell coming through the vents. Now, the fan will not npower on at all. Does it sound like I need the resistor? Thanks.
Old Oct 7, 2012 | 06:11 PM
smokey847's Avatar
Replaced the resistor today, and also checked fuse #37--still no functional fan. What gives?
Old Oct 7, 2012 | 07:20 PM
MrMoPar's Avatar
Probably the blower, I have blowers in my eBay store. Interior Trim, Electrical, switches, etc. items in The Crossfire Shop store on eBay!
Old Dec 3, 2012 | 08:35 PM
coolcars123's Avatar
I have been trying to figure out where the part is located for days...I've opened mostly everything on both the passenger and drivers side, and still wasn't able to figure out where if is located...if anyone could please explain where it is I would appreciate it...is it on the drivers side or passengers side? I even looked at the instructions and couldn't figure out what "lower instrumental panel is"? Thank you
Old Dec 3, 2012 | 09:06 PM
Larry Hitze's Avatar
https://www.crossfireforum.org/forum...r-resistor.pdf
Use this link to help. It is the bottom panel under the glove box on the passenger side. It is not hard to do. I've had mine out before, take this opportunity to change the cabin filter too.
Old Dec 3, 2012 | 10:05 PM
Default
Thanks for your reply. I opened the entire glovebox department and didn't see it when I opened it the first time..this Is really strange as I am good with cars
Old Dec 3, 2012 | 10:12 PM
  #38 (permalink)
UNDER the glove box, right above where your passengers legs/feet sit. The panel is held in place by a number of (if I remember correctly) metric topped screws. Once you get that panel dropped, its super easy to get the resistor/fan motor/filter out and back in. Good luck!
Old Dec 3, 2012 | 11:39 PM
  #39 (permalink)
Metric topped screws?
You mean Torx maybe Phillips
headed screws.
Old Dec 4, 2012 | 07:48 AM
  #40 (permalink)
Yes the key here is not in or through the glove box but underneath.
