Rattle problems - need help
Old Feb 27, 2010 | 01:19 AM
TaReGt's Avatar
Default Rattle problems - need help
Hi,
I am trying to get rid of the rattles in my trunk, since i put the new sub in.
I checked Kolme's post https://www.crossfireforum.org/forum...out-coupe.html but it did not help that much.
So if anybody has any ideas? I know that probably dynamat will help, but i do not want to give $360 for something minor...
Also if someone could explain to me how to take back bumper off, because i think that rattle is coming somewhere behind the bumper. I found DIY but i do not understand where are all the screws?!?!
Thank you in advance
Miroslav A.K.A TaReGt
Old Feb 28, 2010 | 09:35 PM
smokey847's Avatar
Default Re: Rattle problems - need help
What you're hearing in the bumper are the vents. Remove the taillight access panels and you can see them. Turn some music on and they flutter around. Would love to hear how to remedy this.
Old Mar 1, 2010 | 02:21 PM
TaReGt's Avatar
If i know how to take of back bumper, then i can fix that...Any ideas how to take it off?
DIY is not very helpfull
Old Mar 2, 2010 | 12:35 AM
smokey847's Avatar
Not sure. Some have discussed gluing them down but are unsure what kind of problems that may cause. Any ideas what the little vents are there for? What purpose do they serve?
Old Mar 2, 2010 | 02:56 PM
Crossfireone's Avatar
Believe one of the reasons for the vents is to relieve the compression sound & feeling when you close your door & both windows are fully up. Most other car makes I have owned would produce this slight feeling of compression all around since there was no place for the air to escape when the last door was closeed.
Old Mar 9, 2010 | 08:18 AM
Stuckhere's Avatar
Try throwing some Dynamat. My buddy used it on his Civic with the same problem and it worked perfect.
Dynamic Control - Dynamat Xtreme Trunk Kit - 19405
Old Mar 9, 2010 | 02:31 PM
Beaner's Avatar
Here is a pic of vents that Everyone was talking about
Old Mar 9, 2010 | 05:49 PM
Stuckhere's Avatar
Very nice feature I did not know about. Nice pic
tcar32909
Aug 1, 2024 02:41 PM
UNDER PSI
Nov 1, 2015 09:39 PM
nataliefs
Oct 5, 2015 01:03 PM
Abaton6
Sep 24, 2015 10:14 PM
Den656
Sep 23, 2015 12:27 PM
