LED dome lights flicker when I roll windows up or down
So I just got done putting LED interior lights in my xf. Whenever I hit either one of the window switches and let off, the dome lights will flash real quick. Im not sure why its doing this, unless something is on a common circuit and the voltage spike is just enough to cause them to flicker.
Any ideas?
Any ideas?
Re: LED dome lights flicker when I roll windows up or down
Any ideas?
Any ideas?
Mine does the same thing! I have a feeling it has something to do with the energy sensitivity of the LED, as they use so little watts, they are possibly extremely sensitive to the very slightest of light voltage being run though the electrical system. I also noticed the LED's never fully turn off, when i turn the car keys to off, there is always a very low amount of electric flowing though and keeping the LED's very dimly lit.
I am curious why you guys go with LEDs in the dome light? I put LEDs down under the dash because the ease of installation. And to match the light color, I put blue colored (whtie) 194 bulbs in my dome light sockets and they match very close. I understand LEDs use less power, but why are they needed in a dome light?
James
James
James
James
James
James
Originally Posted by AlbertFattal
what exactly would you recomend, i was unaware of a non led that has the same color temperature as other LEDs (the pure white, which is slightly blue)
James
James
Notice the ultra lux brands are doing exactly the same thing?
on
Yeah, my blue led's are flickering when letting go of the power window switch.
I suppose it could come from the window regulator motor. The moment the circuit comes open and feedbacks with the domelight circuit. That shows you how little power is required to light the led's. Perhaps a capacitor in the dome circuit could fix that. However, I know this condition will not cause any problems
Adrian_X
11-09-2017 08:49 AM
Adrian_X
07-12-2015 11:05 PM
