Cup Holder replacement bin
Old May 17, 2010 | 05:20 PM
jediracer's Avatar
Default Cup Holder replacement bin
Hey Guys! Thanks for all your tips, suggestions and help over the last few months. Now I am looking for a bin to replace the cup holder. Anyone have a reasonable contact that can satisfy this? Thanks in advance for your help!!
James
Old May 19, 2010 | 07:29 PM
badge502's Avatar
Default Re: Cup Holder replacement bin
James
I ordered mine from the local Chrysler dealer this afternoon...Part number 1DQ12XDVAA ... $66.50
Old May 24, 2010 | 07:38 AM
blackroadster83's Avatar
You can go to mopar parts and get it for 48$. and get ready for a fun time pulling that cup holder out.
Old May 24, 2010 | 04:21 PM
Larry Hitze's Avatar
Removing the cupholder and replacing it with a storage bin is not that hard to do. If you have any mechanical skills at all it isn't bad. There are many threads on this forum that go step by step with dood directions Here is one from Skinee Minee ( sorry if I spelled that wrong ) also danimal has a very good writeup on the subject. I did it in about an hour start to finish. That rubber handle cover on the parking brake handle is the worst part. I've posted some pictures on it they are in my gallery I believe. Good luck, be careful but remember that it is hard to break anything.
To all members:
I did my due diligence and searched the forums before posting this and the only threads that I could find on how to replace the cupholder became very off topic and didn't give very clear instructions.
So below, here are what I would consider to be detailed instructions for anyone looking to replace the cupholder or access the console.
Tools:
Flat head screwdriver
Phillips head screwdriver
T10 TORX screwdriver
Socket tool (and appropriate socket size)
1. Gently lift up the shift panel by sliding a flat head screwdriver just below the silver trim closest to the mirror control and it will lift up. It is very durable and won't break from this. I personally only lifted it from the part near the mirror control and left the clips near the coin holder/ cigarette lighter attached.
2. Under the trim are 2 phillips head screws that will need to be removed.
3. Remove the rubber cover from the shift lever. This is the hardest part, but don't worry. Many people on the forum suggest using dishwasher soap. That's good and well, but I didn't like the sticky residue that was left, so I saturated the inside of it with some WD-40 in it and it came right off. Wipe off the excess oil off the metal lever.
4. Open the storage bin in the middle console and pull the carpet from the furthest point of the rear about 2 inches up and it will expose 2 lugs that you will need to remove. Do so using the socket tool and appropriate attachment. I apologize for not paying attention to the size.
5. Lift the entire center console up over the shift lever to expose that the mirror control's wires are connected to the vehicle. There are 4 small tabs around the housing of the wires. Use the flat head screwdriver to gently lift them up (they will snap securely when you re-attach it).
6. Flip the console over on a towel or soft area to remove 4 T10 TORX screws that are holding the cupholder in place. This will remove the cupholder which you can keep or sell on eBay (mine is for going on eBay today if anyone wants it).
7. Leave the slot empty until you are done reassembling the entire console back in your car. I found it much easier to have that opening for leverage and to hold by.
8. Reconnect the mirror wiring.
9. Get the metal lever around the rubber opening on the emergency brake and work the console back into place from here. If you don't remove the entire shift trim, then I would suggest having a friend hold the trim up while you get the console back in place.
10. Put the lugs back in the storage bin console. Put the screws back in near the shifter.
11. The 2nd hardest part. Getting the rubber piece from the shift lever back around the metal lever. Again. Saturate the inside of the rubber piece with WD-40 and it will slide on relatively easily.
12. Lift the emergency lever up as high as you humanly can and place a rag around the base of it. All of the WD-40 will slide out the end and catch on the rag.
13. Finally, the new storage bin in replace of the cupholder can slide right into the opening and it will click into place about 90% of the way in.
I personally much prefer the bin to the cupholder already. The cupholder (even when working properly) had such a flawed design that was prone to breaking or spilling. I will never forget borrowing my managers Crossfire and going to Chick-Fil-A to get a #1 combo with a sweet tea. Put it in the cupholder and about 30 seconds later the cup broke out of the holder and sweet tea everywhere in his new crossfire.
The bin is only large enough to hold a cell phone and possibly a wallet. My Blackberry Pearl and Wallet fight for space.
I hope this write-up helps out a little more that the others and if you have any questions, please feel free to ask.
Adrian_X
Apr 8, 2020 02:36 PM
LE Cross
Oct 17, 2016 06:35 AM
LE Cross
Aug 24, 2015 07:05 PM
Xfirenewbie
U.K.
Aug 13, 2015 04:39 PM
axnguyen
Jul 21, 2015 11:41 AM
