Interior door grab handle burrs
Old Jul 26, 2010 | 05:55 PM
SRT6T9's Avatar
Default Interior door grab handle burrs
I had an issue with my 05 SRT-6 Roadster. Since I have owned this sweet ride. I have noticed that on the inside of the interior door grab handle has sharp burrs that will cut your fingers when closing the door while seated. Since the grab handle appears to be wrapped wih brushed stainless sheetmetal or aluminum with the sharp edges of the seam located right were your fingers contact the back of the handle causing cuts when you close the door. I deburred mine by using a small jeweler's fie and care not to scratch the exposed brushed finish of the grab handle.
So far this has been my only issue with the car. I bought it 18 months ago with only 2900 miles on it. I've put almost 2000 miles on the car since then.
I do have to say the crossfire SRT-6 is a nice performnce sportscar for the money.
thx.
SRT6T9
Old Jul 26, 2010 | 06:08 PM
robby363's Avatar
Default Re: Interior door grab handle burrs
If you still have the 3year/ 36,000 mile warranty they wiil replace them. I had to have mine replaced for the same reason. You can find the TSB file here on how to replace it if you don't have a warranty.https://www.crossfireforum.org/forum...or-handle.html
Old Jul 26, 2010 | 06:48 PM
We noticed ours about three months after the warranty.
When they honored the waranty on Cathy's Control Module,we thought about slippin' it I but actaully didn't want to kick that pig.
So, I simply sanded them off. Can't see it anyway.
franc
Old Jul 26, 2010 | 10:23 PM
Larry Hitze's Avatar
I cut the burrs down with a knife and than carefully applied a thin strip of that alum. furnace tape to the backside to prevent more comming loose.
Old Jul 26, 2010 | 10:29 PM
That is a good idea. I was gonna use old reliable duct tape.
I like your solution a lot better.
Thanks.
fanc
Old Jul 27, 2010 | 09:08 AM
It won't dry rot like duct tape but man is it sticky. Better have it where you want it when it sticks.
Old Jul 27, 2010 | 10:38 AM
OKC-XFR's Avatar
I put a strip of just the soft half of Velcro tape over the seams.
Old Jul 27, 2010 | 11:01 AM
NeedsWings's Avatar
i have a strip of electrical tape on the inside of our passenger door handle that had the same problem
Old Jul 27, 2010 | 11:10 AM
mrphotoman's Avatar
mine did not have that issue but as a preventative measure i took the fuzzy side of black industrial velcro and ran it along the back of the door handle. it feels nice and is stuck there for good unless of course i want to remove it. you can not see it back there so i have no reason to take it off.
you can get the strong adhesive industrial velcro in rolls at walmart for cheap. i use that stuff for everything. i even used it to hold a mini dry cell battery in my old car and it held up to road racing and everything.
Old Jul 27, 2010 | 11:11 AM
mrphotoman's Avatar
lol i just seen your post, the velcro works great doesn't it! i never go without a roll of velcro, i use it for everything.
Old Jul 27, 2010 | 12:57 PM
bmorgan's Avatar
I sanded the back side down and then covered them in Neffy Wrap. I like the look and feel.
Old Jul 27, 2010 | 01:03 PM
JHM2K's Avatar
Bob, I need to give you a shout about Neffy. Specifically, the ease of application on console pieces.
You going to make the ATL meet in about a month?
Old Jul 27, 2010 | 01:04 PM
I've never heard of that stuff but it does look nice.
Old Jul 27, 2010 | 01:24 PM
OKC-XFR's Avatar
About 2 years ago I picked up a 100ft. roll (both sides) and I'm down to about 25 feet left - the stuff is fantastic!
Old Jul 27, 2010 | 02:21 PM
mrphotoman's Avatar
lol it is better than duct tape and WD-40!
Old Jul 27, 2010 | 04:26 PM
bmorgan's Avatar
Hey John... You have probably noticed that I have not been around much lately. I have been occupied with other things, but I do plan to get a bit more active again soon. I need to mark the Atlanta GTG down in my calendar. I will plan on attending. The Neffy Wrap was very easy to work with, and looks fantastic in person. I look forward to seeing you and others in Atlanta.
rocketrage
Oct 7, 2015 05:00 PM
xfClifford
Sep 6, 2015 08:20 PM
PHeez
Aug 11, 2015 01:30 PM
xfClifford
Aug 3, 2015 11:03 PM
waldig
Jul 15, 2015 02:05 PM
