Dash lights
I have a 2005 Roadster and all the dash light work except the radio and the lights below it in the *****. Does anyone have any ideas what could be the problem. The left **** on the radio light up at night but the rest of the radio and all the lights below it do not work. Any help would be appreciated.
Might need to check your fuses under the hood. If you have the basic manual it has a listing of what they all are. There are a couple different ones for separate sections of the dash lighting. The cluster is one and the center is another, can't recall the exact setup ATM. Post what you find or if you don't have the book. The forum search tool may lead you in the right direction as well.
Edit:: Reading back through the question this may not help if the only lights out are in the radio itself, that would most likely be an issue with the unit.
Danyuhl
Nov 2, 2019 05:18 PM
xfClifford
27
Nov 10, 2015 10:08 PM
