My free cupholder turned cubby hole mod...
![Default](https://www.crossfireforum.org/forum/images/icons/icon1.gif)
Hadn't seen this done anywhere on here, so thought I post some pix. I've been wanting to replace my cupholder for a while now, but the biggest hold (other than the price) was whether or not the opening would bother my arm. So, figured I'd just pull the cupholder out, and see how it felt. After a little closer inspection I found the cupholder just pops out of it's "holder", which makes a great storage compartment. It has a large hole on the side, and a smaller one at the rear (which is mostly blocked). For now I just put black tape on either side to block the hole. Figured I'd make a couple plates out of thin steel sheet, then cover the inside with felt (assuming it doesn't bother my arm). It's almost too deep, but I think it will work. I plan to put my phone and wallet in there instead of the larger center console. BTW, I have an HTC Evo 4G, and it drops in completely.
![](http://i186.photobucket.com/albums/x40/closer9/IMAG1336.jpg)
![](http://i186.photobucket.com/albums/x40/closer9/IMAG1340.jpg)
![](http://i186.photobucket.com/albums/x40/closer9/IMAG1337.jpg)
Now, just gotta figure out how to pull apart the center stack, so I can get the bulb out of the hazard switch. It's going to drive me crazy once the days start getting shorter, and I start driving more at night.
Great mod, thanks for the info. If you decide to make a inner liner that works, let me know and I would be happy to purchase one for me, if you were willing. I have CF wrap and since it will be nearly non-visible, I think I may just cover the liner in that, let me know if you are interested. Thanks!
