Fan non-functional
Old Sep 21, 2012 | 06:09 PM
smokey847's Avatar
Default Fan non-functional
Was driving with a friend today, turned the AC on to cool the cabin down, then we smelled a horrible burning rubber smell. Because I had company, I just turned it off to worry with it later. I've learned since then that the fan will not even turn on, whether it's on 1 or 5 speed. Any ideas?
Old Sep 21, 2012 | 06:13 PM
Default Re: Fan non-functional
Most likely the fan control/resistor board that is attached to the bottom of the fan.
see https://www.crossfireforum.org/forum...where-get.html
Old Oct 7, 2012 | 06:03 PM
smokey847's Avatar
Replaced the blower resistor today--still no fan. Also checked fuse #37 and it is still good. What could it be?
Old Oct 7, 2012 | 07:19 PM
The blower motor, or the control panel assembly.
I'd try the blower motor first, it's cheaper.
Old Oct 7, 2012 | 11:37 PM
I have the same problem. Still trying to source the problem.
Mercedes,,,best engineered cars in the world, made with the cheapest parts.
Old Oct 11, 2012 | 01:44 PM
smokey847's Avatar
Pulled the blower motor yesterday. To test it, I hooked it up to a 12V power source, which made it blow full speed; however, there was a horrible electrical burning smell while it was running. Any ideas?
Old Oct 11, 2012 | 02:00 PM
waldig's Avatar
Talking Re: Fan non-functional
Shorted -partially windings. Motor will overheat if current is too high. Woody
Old Oct 11, 2012 | 02:25 PM
smokey847's Avatar
So, then, what would you advise to replace?
Old Oct 11, 2012 | 02:36 PM
The fan.
It should run fine when hooked to 12v without smelling or smoking.
Valk
Jul 12, 2021 09:49 PM
Nov 11, 2015 05:22 AM
Oct 1, 2015 01:42 AM
RiderJC
Sep 7, 2015 11:19 PM
williammt
Sep 6, 2015 11:23 AM
