Interior door bars
Old Dec 11, 2012 | 09:00 PM
Sandy's Avatar
Default Interior door bars
I don't know where to post this, but I've noticed the 2004 Crossfires interior door pull bars can cut your finger. The back of that silver bar is rough. I bought 2 seatbelt cushions that are cylindrical, anyway, and placed them around the door pulls. Attractive, comfortable, and safe!
Old Dec 11, 2012 | 11:20 PM
Bill F's Avatar
Default Re: Interior door bars
That is what I did before my door pulls start to wear and become jagged. It seems that many Crossfire owners has had that issue.
Old Dec 12, 2012 | 12:12 AM
Mongoose57's Avatar
I think this would be the perfect place for some carbon fiber wrap, good looking and takes care of the rough surface .
Cheers
Mongoose57
Old Dec 12, 2012 | 12:25 AM
Cheers
Mongoose57
You think it's great and many do not agree and think carbon wrap is over done and looks like crap. You think it looks good and I think it does not. If it's real carbon fiber OK, wrap is ***** to my mind. Each to their own I guess. It is nothing but glorified MacTac.
Old Dec 12, 2012 | 08:24 PM
Mongoose57's Avatar
I have to agree with you,I have never used the product and was only speculating
That there was a high end product that could be used. You see a fair amount of carbon fiber at car show's these days so I thought quality rap would be readily
Available.
Cheers
Mongoose57
Old Dec 12, 2012 | 09:45 PM
Jackerman's Avatar
Mines beggining to tear on the driver side and actually cut my finger the day i bought it
The passenger side is just fine, the carbon wrap was great idea may do that
Old Dec 13, 2012 | 12:24 AM
user 72983's Avatar
Banned
I used the soft half of Velcro tape on the inside of the door pull. I like it. I was cut a number of times.
DJ
Old Dec 13, 2012 | 07:22 AM
DJ
Now that's thinking outside of the box !!
Wish I had thought of that ......
( it would feel something like grabbing ....... uh something else )
Old Dec 13, 2012 | 09:25 AM
I just used a piece of fine grit sandpaper and sanded the inside, looks OEM with zero fingers cut
Old Dec 13, 2012 | 09:57 AM
Jackerman's Avatar
Great idea, gonna do this later
Old Dec 13, 2012 | 02:01 PM
I forget who told me, but it worked well, just passing along stuff i have picked up here
Old Dec 13, 2012 | 02:25 PM
It worked for me, my '04 was perfect and the '05 not so much. The passenger side got quite sharp, a rub with the fine foam sanding block did it, for now anyway.
The earliest post on sanding I could find.
Old Dec 13, 2012 | 05:45 PM
user 72983's Avatar
Banned
I tried to sand it...but it seemed to make it sharper! But, if it works for all others, great
I learned about the Velcro thing on XF.org, I think...
It does feel fuzzy, warm...mmm.
No really, I also thought about wrapping it with leather. But this seem to work great for me.
The cuts were really bad! I play guitar, so I watch my fingers.
Old Dec 13, 2012 | 09:17 PM
syfi's Avatar
I was thinking about trying some silver Neffy wrap around the handles. It's a little thicker than the normal wraps and should match up nicely, plus it has some cush to it!
Old Jan 10, 2013 | 10:38 AM
terry b's Avatar
sanded mine with fine foam sanding block. Worked great - smooth as silk.
Old Jan 10, 2013 | 11:04 AM
sk8erjosh09's Avatar
For some reason I have never had this problem, but if I did sanding would be the way I went too. The other cool idea was the leather wrap, I know I saw pic's somewhere of it done. It looked amazing.
Old Jan 11, 2013 | 08:59 AM
Leather looks ok if it matches the interior, but unless you make them velcro, you could no longer remove the door panel with them installed
Old Jan 11, 2013 | 09:45 AM
JHM2K's Avatar
I think Musclefan21 had leather-wrapped door handles... but, his were also made of wood because the PO had broken the plastic ones
Old Jan 11, 2013 | 10:42 AM
P05Crossfire's Avatar
I used 3/4" 3M clear tape down the entire seam 5 years ago and have never been cut, plus the tape can not be see.
Old Jan 11, 2013 | 11:17 AM
That was what I was referring to, I remember the first set he had to destory to remove them to access the door panel...
