Interior door bars
Old Jan 11, 2013 | 11:25 AM
Default Re: Interior door bars
Leather looks ok if it matches the interior, but unless you make them velcro, you could no longer remove the door panel with them installed
My car came with those leather wraps that laced up on the back face. I did not like them and took them off. Someone on the forum was making them at one time.
I sanded the back of the pull to make it smooth, I had to do it twice though, maybe I'll have to do it again.
Old Jan 11, 2013 | 11:31 AM
JHM2K's Avatar
Originally Posted by P05Crossfire
I used 3/4" 3M clear tape down the entire seam 5 years ago and have never been cut, plus the tape can not be see.
That's what I ultimately did with mine. After sanding the flash down, I used some heavy-duty 3M ultra-clear packing tape. I applied it with the same method one uses to apply vinyl (lubricant spray) and worked all the bubbles out. No one has ever noticed.
Old Mar 10, 2013 | 08:24 PM
TomKat's Avatar
I had the same problem with the drivers side on my 05 , so I cut a 1" strip of aluminum duct tape and ran it down the entire seam. Works great and cannot be seen.
88stevie
19
Jan 21, 2026 01:46 PM
rocketrage
Oct 7, 2015 05:00 PM
PHeez
Aug 11, 2015 01:30 PM
waldig
Jul 15, 2015 02:05 PM
