Side View Mirror Switch Fell Through Console
Old Jan 29, 2013 | 08:11 AM
uknowhim21's Avatar
Default Side View Mirror Switch Fell Through Console
So as the title says, my side view mirror switch fell through the console when I accidentally hit it with my briefcase. Now do I need to take the whole console apart, starting from the radio and working my way down in order to remove the section where the mirror switch goes through? I don't want to try and pull that single section up and break it. So hopefully someone here knows what to do. Thanks!
Old Jan 29, 2013 | 09:06 AM
Bill F's Avatar
Default Re: Side View Mirror Switch Fell Through Console
I did a search and this is what I found.
https://www.crossfireforum.org/forum...tml#post451353
Old Jan 29, 2013 | 09:11 AM
http://How-remove-center-console-how...r-switch (PDF)
Bill meant to say :
https://www.crossfireforum.org/forum...or-switch.html
Old Jan 29, 2013 | 11:03 AM
uknowhim21's Avatar
Thank you Bill! I didn't even think of doing a search considering I didn't think this was an issue. I appreciate your time and help.
uknowhim21's Avatar
Originally Posted by alaxfire
Thanks for your help as well. This is why I love the forum. You guys are the best!
Old Jan 29, 2013 | 11:13 AM
Bill F's Avatar
No I didn't. I posted "I did a search and this is what I found". Didn't know that info was available.
Old Jan 29, 2013 | 11:31 AM
Bill F's Avatar
You're welcome and glad to help, hope it is an easy fix. It is great that so much info is available on this forum.
Old Jan 29, 2013 | 12:23 PM
uknowhim21's Avatar
It looks like it will be. Im going to tackle it tomorrow since it will be in the 50's in NJ haha
Old Jan 31, 2013 | 11:26 PM
Unkwnsoldier's Avatar
Na, its simple. Rase up the piece where the shifter it. Two screws there, open up console compartment. Two nuts there, slide e break pad off of e break, lift up, console comes right off. I replace my mirror *** and cup holder at the same time. Took 15 min. If that.
Old Feb 1, 2013 | 09:23 PM
uknowhim21's Avatar
[QUOTE=Unkwnsoldier;721881]Na, its simple. Rase up the piece where the shifter it. Two screws there, open up console compartment. Two nuts there, slide e break pad off of e break, lift up, console comes right off. I replace my mirror *** and cup holder at the same time. Took 15 min. If that.[/Q
Yah I did it today after work. Took all over 5 minutes. Thanks to you and everyone else for the help.
PNA
Nov 12, 2020 04:44 PM
Hoppy
Dec 7, 2018 07:36 AM
pioneer4x4
Oct 6, 2018 01:09 AM
66L72M21
Jul 15, 2015 04:23 PM
Rjono
Jul 15, 2015 03:29 PM
