auto shift knob removal
Old Oct 2, 2014 | 07:08 PM
conner309's Avatar
Default auto shift **** removal
all the threads ive looked at say to unscrew bottom piece and then lift up on ****. I just went out with pliers and turned the **** out of the bottom "locking" piece and it wont even budge. help?
Old Oct 2, 2014 | 07:49 PM
Bill F's Avatar
Default Re: auto shift **** removal
You need to take a razor blade and go around between the bottom piece and the **** to break the seal they used.
Old Oct 2, 2014 | 08:14 PM
earlj's Avatar
I had difficulty removing my shift ****; however, when I moved the shift **** until it was in a perfect 90 degree position, the shift **** came off. When you put the **** in a 90 degree position it gives you a better holding grip thus allowing you to remove the shift **** more easily.
Old Oct 3, 2014 | 07:10 PM
lildaddym's Avatar
Don't forget that the bottom is reverse-threaded...
Old Oct 4, 2014 | 03:34 AM
power90801's Avatar
After I unscrewed that bottom collar the **** slid straight up and off with a little encouragement, easier than I expected for sure.
Crossfireone
23
Aug 25, 2015 04:56 AM
chturner
Aug 23, 2015 06:14 PM
Cuda56
Aug 11, 2015 12:11 PM
XFIRED-TX
Jul 17, 2015 11:56 AM
XFIRED-TX
Jul 14, 2015 10:48 PM
