D/S Door pull
Old Jan 7, 2015 | 05:38 PM
mbpsycho's Avatar
Default D/S Door pull
Close my door and the main bar came off in a second ......any way to repair i don't want to spend 220.00 for a new one ....i found a passenger side one but the guy says there different they look the same to me if you 180 the base piece
Old Jan 8, 2015 | 08:54 AM
Bill F's Avatar
Default Re: D/S Door pull
Did a little search and found this:
Interior Door Pull Handle Repair/Retrofit with Pics - CrossfireForum.org
Old Jan 8, 2015 | 10:09 AM
If you try to put the left hand cover part on the right hand main pull part you will find they have a different curve and not fit at all. They definitely are left and right assemblies.
The fix outlined by MAGNATUDE in the above post is a great fix.
It is converted to a PDF and stored in my How to fix thread below.
Click here for a printable copy.
Old Jan 8, 2015 | 07:09 PM
cg80's Avatar
Used it Dave and works like new...Thanks...Carl
Old Jan 9, 2015 | 04:14 PM
mbpsycho's Avatar
Thanks for the research Bill.....i will use it if the used one is no good i'll find out this weekend after the guy pulls it
Franc Rauscher
May 9, 2016 12:04 PM
Mackel
Oct 16, 2015 09:03 AM
tritongreen
Sep 18, 2015 07:32 AM
xjken
Sep 13, 2015 10:18 PM
jaesa
Sep 7, 2015 01:50 PM
