How to brighten or dim dash gauge lights
Old Aug 11, 2020 | 07:01 PM
Jim Holian's Avatar
Default How to brighten or dim dash gauge lights
Gentlemen - I went thru my owners manual to try and find out how to brighten or dim my gauge lights on the dash. The manual says to push in on the light control **** and rotate to change the intensity of the dash lights. My XF is a 2005 Limited Coupe. Doing as the owners manual says does nothing for the gauge lights. All it does is either turn on the headlights or the parking lights, depending on which way the **** is turned. Does anyone have a solution for this problem? The manual should be correct but it's not working for me. I tried it with the car running and with the engine off - no difference. If you can help me out I'd love to hear from you.
Jim
Old Aug 11, 2020 | 07:23 PM
dcskmail's Avatar
Default Re: How to brighten or dim dash gauge lights
Your're using the wrong ****. The adjustment for your dash lights is the little silver **** that looks exactly like your odometer reset ****. it's between your gas gauge and speedometer. At zero the red speedometer needle points directly at it. just turn it to adjust ,you don't have to push it in
Old Aug 11, 2020 | 08:37 PM
user manual :
22. Push Button for Activating the Instrument
Cluster, Intensity of Instrument Lights, for Resetting
Trip Odometer and Flexible Service System (FSS)
Indicator
Press the ****/button to illuminate the display. To vary
the intensity of the instrument cluster lights, rotate the
****/button
Old Aug 12, 2020 | 10:00 AM
Jim Holian's Avatar
Gentlemen - Thank you both for helping me out. Your explanations are better than my owners manual.
Jim
FabianMoody
Feb 26, 2013 10:34 AM
zombiehunter
Jul 30, 2011 08:48 AM
IMPERIAL4EVER
Feb 13, 2009 10:23 AM
redxfireroadster
May 23, 2005 01:30 PM
