water in floor pan behind driver seat
Old Nov 1, 2020 | 12:18 PM
lkxfire's Avatar
Default water in floor pan behind driver seat
Having trouble tracking water entering the floor pan behind the driver seat on a 2004 base model. Have checked and tested wiper drains and no issues at all. Door window is tight, door seals good and no issue with small side window, hatch wiring grommet appears very good and stabilizer wing drains good...where is the water entering driver side of car coming from? Any body else with this issue??? Lorne
Old Nov 1, 2020 | 06:57 PM
Toolman's Avatar
Default Re: water in floor pan behind driver seat
Maybe the body plug behind the driver seat is missing.
Old Nov 1, 2020 | 07:13 PM
I had this issue awhile back on my 2007 Coupe. Ended up being water entering thru the threaded holes where the factory dead pedal was mounted. I had removed the factory one and installed a M-B version that matched the bright pedals in the Coupe. What I was never able to understand is why this wasn't an issue for a couple of years after I installed the M-B dead pedal and then suddenly allowed water to enter the floor pan.
Keep telling myself to remove the factory dead pedal, plug the holes for the screws and then re-install the M-B dead pedal. Curious if water comes back
Old Nov 12, 2020 | 12:09 PM
VintageBikesUSA's Avatar
do you by chance have a part number for the dead pedal from MB?
Old Nov 12, 2020 | 04:54 PM
Dead Pedal isn't actually a M-B part. It is a "look-alike" that is of reasonable quality. You can do a search on eBay or Amazon (where I purchased) using the following:
Stainless Steel Footrest Foot Rest Dead Pedal Pad Cover For Mercedes Benz A B C E S CLS SLK CLA GLA GLK ML G GL Series
Dead Pedal is somewhat universal across M-B product lines. Cost me $20. I used industrial strength, double-sided tape to hold it in place. Worked fine; never had the dead pedal come loose.
Happy Hunting
dogwood_laine
Apr 11, 2022 11:56 AM
lildaddym
May 10, 2014 11:27 PM
gawron73
Jun 16, 2012 04:18 AM
lee e
Oct 13, 2009 11:50 AM
blackcrossfire07
Mar 15, 2009 06:28 PM
