Interior door handle not opening door
Old Oct 6, 2021 | 04:36 PM
notloc's Avatar
Default Interior door handle not opening door
HI all, recently my crossfire's driver side interior handle has lost tension til about halfway through pulling it. Upon opening the door, the cable and plastic pieces seem to be intact, as pulling on the cable will open the door, and the cable was still attached to the handle when i removed the door panel. Is there a replace cable that you guys are aware of that I could scoop? I looked on ebay with no luck. Any other ideas of how I could get some tension on the cable without replacement is welcome also. Thank you.
Old Oct 7, 2021 | 08:54 PM
zip439's Avatar
Default Re: Interior door handle not opening door
That cable does not stretch; More than likely it is not routed properly. Look at the thread for door panel removal. Perhaps there is a picture that will help you..
Old Oct 7, 2021 | 09:28 PM
Here is a photo of the inside of the door showing the cable that opens the door lock.
Old Mar 6, 2024 | 08:47 PM
paintergman's Avatar
I know this is an old thread but were you able to solve the issue with the interior door handle ? I’m currently having the same problem. The cable looks to be routed properly it just seems to have lost tension. Can’t tell you how annoying this has become. Any input would be appreciated.
Old Mar 6, 2024 | 09:43 PM
notloc (original post) has not been active on the forum ...........Last Activity: 12-22-2021
You are not likely to receive the answer to your question
Old Mar 7, 2024 | 01:08 AM
If it's a tension issue, maybe you could put a couple of split washers on the cable near wear it connects to the pull handle to increase the tension. Other than that, you might have to replace that cable. Just a thought.
rpxmayor
Dec 4, 2019 05:42 PM
White Thunder
Jun 27, 2018 03:37 PM
SrWilliams
Feb 17, 2013 10:19 AM
orlando2128
Jun 12, 2012 07:51 PM
yorktown4
Sep 27, 2010 08:55 PM
