Racing The place to talk about autocrossing, road and drag racing.
Post Race Inspection
Old May 26, 2006 | 05:17 AM
HDDP's Avatar
Default Post Race Inspection
I forgot about many of these shots after my last race. Here's what I do with the car to inspect it for damage after a weekend on the track.
I lift the car and inspect and remove the tires and inspect them for road damage and also look at how they contacted the surface of the road. These took a beating on the inside tread if you notice the third rib in is worn lower than the outside... Probably means I need to run more PSI with those tires if I ever use them again... They are Michelin PS Cup Comps and I was running 34 psi in the front.
Then I rip into the lower part of the car to check for damage or wear. I always inspect the rotors and pads and replace them about every three races.
https://www.crossfireforum.org/forum...1&d=1148634666
Then I leave the car up on stands so the springs and dampers release and keep a consistant performance.
xfClifford
Mar 3, 2021 04:52 PM
pioneer4x4
Mar 25, 2019 10:35 AM
wannaGOFAST
South Forum
Aug 14, 2015 01:20 AM
IsaacF
Aug 13, 2015 07:01 PM
waldig
Jul 15, 2015 02:05 PM
