Well I dood it.
This time tomorrow a new resident should be here, an '07 Limited Coupe in exactly what I said I didn't want: Black but with Cedar interior (black/red can be sharp). Bit over 100k miles but very well maintained and a central Florida car all its life.
So have the Clarion M303 on order since need handsfree and aux input and am wondering if a 10" tablet on the glove box door would be touchable. Ergonomics should be interesting since CF is very close to Fiero size (actually 6" shorter)
Also coming is a Mini BT OBD-II dongle to avoid hitting with clutch foot.
Anyone know if a 2.6 ring & pinion from an E320 will fit the Crossfire pumpkin ? I really want a sub-2000 rpm 70 mph cruise and do not need a granny 1st. 2500 @ 70 does not make for good MPG (that is what a four speed Fiero GT turns and him don't either). That many with a 3.2 V6 & 6 speed is just abby-surd.
(Actually what is absurd is that my Grand Cherokee with Pentastar gets the same MPG with higher compression on regular)..
I have often thought we have the perfect transmission - if you plan to pull stumps in 1st gear.
Or if the engine had 60 less horsepower. I know a few here who don't even use first. I use it as a clutch-saver.
There was a problem with the early ones and it was a fixable problem, so look for the fix if that is the problem.
If it is a 2005 there was a TSB on this issue 21-005-05 for trans s/n 1 692 154 - 1 788 079 "may experience disengagement from first gear".
Must admit part of the attraction was all of the online documentation.
The easy fix is buy an auto or SRT.
I think this is just a misadjusted shifter. If I engage it properly, its fine. Half the time I don't even use first gear.
Once you have the tranny out it is not so bad unless you have a plethora of needle bearings to keep track of.
I once rebuilt a lunched trans for an A/SR (SCCA) on the back of a trailer during the break and since the synchros were all mangled just made it a crash box. Won the afternoon race but I put 90% STP plus 10% ATF in it and the lube acted to match the gears. Did have to double clutch down.
Only caveat is that if it is a Moss gearbox (XK Jags) best have a set of Whitworth wrenches.
BTW three of the vehicles in the .sig have manual boxes.
ty_ty37
Jun 27, 2024 10:42 AM
crossfireusa
Oct 28, 2015 12:03 AM
