Fuse info
Fuse info
I have two 05 coupes, a SRT and NA, the SRT has yellow card in the fuse box cover with the info on each fuse. My NA does not have one, since it is the base model my guess is it is different than the SRT. Could some one with a base car make a photostat of theirs and send it so I can have one for the car?
Thanks
Dan
Thanks
Dan
on
Re: Fuse info
This is a scan of the fuse box label on my SRT.
Note that some fuses are in brackets and they are not on the SRT, does one label cover all years or just the year 2005 fuse positions. Checking with the owners manuals should answer this question.
This actual scan could be modified to show any changes using Photo Shop or a similar program.
Re: Fuse info
Why put a SRT fuse in brackets when it actually came from an SRT, and fuses for an NA where also in brackets, get let? Convertibles may be different again.
Maybe from 2005 on all labels might have been the same if not PhotoShop could make it slightly different.
Sometime back a member with an SRT that was missing this label printed this photo for his car.
Re: Fuse info
Seat relays are not on the base cars but oddly on this label they are not in brackets while the garage door opener is.
Jesticle
05-20-2011 02:42 PM
