Rear Venturi Info
Old Nov 15, 2006 | 06:19 PM
HDDP's Avatar
Default Rear Venturi Info
I just received the rear venturi's from: http://www.chryslerpartsdirect.com
If anyone is interested in purchasing this item, it is officially called "Rear Fascia Closeout Panel" part #'s 82209208-LH & 82209208-RH. They were a special order and cost $198.34
I will post a photo when they are installed...
Old Nov 15, 2006 | 08:55 PM
dynamicS's Avatar
Default Re: Rear Venturi Info
I bet you could have a sheet metal guy stamp those venturi's out of Aluminum sheet for $50 a set. Just add paint!
Old Nov 16, 2006 | 01:12 AM
Sennaspirit's Avatar
Derek, post a pic when you can. I can't seem to find it on that site, with the part number or under "rear fascia..."
Old Nov 16, 2006 | 02:48 AM
HDDP's Avatar
Call and ask for Lenny at (888) 473-9069.
Old Nov 16, 2006 | 06:11 AM
xfirecorea's Avatar
Please forgive me for my ignorance, but what exactly IS a "Rear Venturi"?
I am guessing that it would be similar to the Crossfire rear diffusers supplied by CTD or Startech...
By all means, I would appreciate it if someone can correct me if I am wrong.
Old Nov 16, 2006 | 06:58 AM
bobs's Avatar
I ran the part # through google. Here's a picture.
http://www.earnhardtchryslerparts.co...26_275156.html
Old Nov 16, 2006 | 07:29 PM
Iamfink2's Avatar
You can get the rear fascia accents at this site for $177.00. http://www.wyckoffchryslerparts.com/index.html
Old Nov 16, 2006 | 10:14 PM
Thanks bud...I've seen those before, it's a Diffuser and I think these are a bit "chunky" looking for my taste. I wish someone made a thinner and slightly taller set of splines/fins. Here's a ferrari with the "form" I'd like to see...
http://www.gmpperformance.com/index....large&IMG=7110
amx1397
Jan 24, 2016 02:12 PM
Sep 13, 2015 02:12 AM
maxcichon
Sep 4, 2015 12:50 PM
stlas69
Sep 3, 2015 10:28 AM
BrenLW
Aug 5, 2015 04:53 AM
