Thomas Knight Xfire Aftermaket Turbo
Old Nov 20, 2006 | 09:28 PM
x'ed's Avatar
Default Re: Thomas Knight Xfire Aftermaket Turbo
Originally Posted by dynamicS
I tried to click on the link to the article and it wouldn't load for me, so NO I did not read the article!
OK so they where able to get 10 psi, but that's just pressure and may not be sufficient volume of air to feed the 3.2 motor. And this system might create a large amount of lag time before it will provide a full 8 psi to the motor due to such small impeller and trim size. Also if you are running the stock intake manifold, that is also quite a bit of plenum volume to fill on top of filling the pistons. so there is more lag time created by filling the NA tuned intake.
When I referred to "Total Package" I was wondering how much for a completed kit, much like an Edelbrock turbo kit for a Honda.
Now, my question is, you think that dinky little blower will produce 75 hp? I don't think so, I just cant fathom that blower can possible put out any CFM.
I believe Kleenmans Supercharger puts out 6 psi, but it has much more impeller area to flow a decent amount of CFM.
You lost me on the paragraph about mounting batteries in the trunk, please explain that?
just please read the link. just erase the end of the link, go to the main page and search "thomas knight" or google "thomas knight" and the article will come up. this isn't a turbocharger, doesn't spool like a turbo, no impeller is controlled via exhaust. its a complex unit that provides shorts bursts of power at a time. it has dyno'd at 100 whp on top of the base car power. read the article, the things you spew will pollute pages...
Old Nov 20, 2006 | 09:41 PM
dynamicS's Avatar
Originally Posted by psuperti
Go here: http://www.boosthead.com/product.php?id=18
after you read it all...
look at the dynos...
watch the video you wanted to see...
then will talk, ok?
it should all look like this:
Click on one!
V6 Avenger Dynos
Moroso Timeslip 2/8/04
Moroso .WMV (6.3MB)
ESC INSTALLATION INSTRUC
Any pictures of the actual installation of the alternator supercharger in the Altima?
Didn't you state that Thomas Knight actually installed a system on the crossfire? Maybe that was from another thread?
Old Nov 20, 2006 | 10:00 PM
MMZ_TimeLord's Avatar
x'ed,
I read on the Thomas Knight site that it was simply an extended shaft on a replacement alternator that allowed the existing belt to drive this 'supercharger'. I do not understand how you figure you would need more batteries for this type of installation.
On his 'electrical supercharger' system, then yes you would need the additional batteries to allow for the electrical drain during operation and a second alternator to recharge those extra batteries. The electrical supercharger system that they have utilizes several high RPM starter motors to turn the impeller(s) of the supercharger and are a serious amperage draw.
I to enjoy your posts x'ed, I am enjoying them now... we all need to keep everyone on track and try to avoid confusion on this stuff so the correct information is presented so it can be evaluated for the best benefit of the forum users.
Cheers!
Old Nov 20, 2006 | 10:06 PM
psuperti's Avatar
Yes, he did one system on a crossfire in 2005. No one know whose it is except that it was a silver one. Yeah it sounds like b.s. I honestly don’t care and it makes me mad that Knights web site sucks and is out dated but he promised me pictures and info for us to analyze/criticize.
Now don’t disregard the link I posted on the installation instructions because that answers your question about Blow off valve and other parts that might make this system really kick some butt for 2.2K - 3K.
Old Nov 20, 2006 | 10:11 PM
psuperti's Avatar
I think this is a 2.5L Ranger.
Old Nov 20, 2006 | 10:47 PM
bourneyesterdayi's Avatar
Default Re: Thomas Knight Xfire Aftermaket Turbo (Supercharger?)
A small supercharger pushing 8 PSI = Very fast turbine speed. That means a very hot turbine. A hot turbine means hot air, and no Aftercooler/Intercooler was mentioned anywhere in this post. The supercharger would be running off what, one air filter? And where would that air filter be positioned exactly... A supercharger is supposed to give you high power at low to medium rpm and no lag. At slow speeds your air filter will be sucking in all the hot air from inside your engine bay, heating the air up even more on acceleration by the high speed turbine, directly into your engine... Until you reach a decent speed where cold air rushes through the grill into your air filter your will probably be getting some pretty lacking performance, possibly even worse than turbo lag... Now if somehow you can install that aftercooler/intercooler, and position the air filter in a decent spot somewhere in the front of the engine bay... Hey at least you have bragging rights that you have a supercharged Crossfire though eh?
But what do I know I'm just a kid.
Old Nov 20, 2006 | 11:03 PM
psuperti's Avatar
OK we all need to read on this before we post. Look, this super charger only works when you hit the pedal to the medal! So you would be going quite fast. Then if you install this right, you would use a bypass valve to give the engine air when the ESC is not in use, say when you do your city driving.
Old Nov 21, 2006 | 12:27 AM
dynamicS's Avatar
sorry man, but that's no Ranger, they're RWD not FWD.
Old Nov 21, 2006 | 12:28 AM
dynamicS's Avatar
this thread is a joke!
Old Nov 21, 2006 | 01:51 AM
x'ed's Avatar
your posts are a joke...explain to me how a proven 3 second drop in quarter mile times and a 95 whp increase on a dyno are disputable. you guys are ridiculous, the same people that kill every mention of a mod and sway everyone away from doing any serious mods. until you can prove it doesn't work, then why offer your opinions. thomas knight is a respected and patented engineer. get some proof to back up your claims. you and "the kid".
Old Nov 21, 2006 | 01:53 AM
x'ed's Avatar
if you read the article you will see boost is actually higher down low and drops off from there. READ IT.
Old Nov 21, 2006 | 11:10 AM
psuperti's Avatar
I agree with X'ed, and who every gets this mod is going to be as fast as a SRT6.
I don't see why dynamics a senior member who I respect, has to come in here and say that this thread is a joke. Look around this is the only interesting thing we have talked about for a while, every one is talking about the same old stuff (buy or sale xfires) there is nothing wrong with that, but we have the right to study the Thomas Knight ESC.
Although the ESC follow the basic rules of a supercharger, it is a very unique system and all that we are asking is for people to be well informed about it so we don not have pages of junk.
Old Nov 21, 2006 | 11:15 AM
psuperti's Avatar
Tis is the short cut to the info, Click on one!
V6 Avenger Dynos
Moroso .WMV (6.3MB) (VIDEO)
ESC INSTALLATION INSTRUC (Parts, etc)
Old Nov 21, 2006 | 12:08 PM
psuperti's Avatar
Old Nov 21, 2006 | 12:12 PM
psuperti's Avatar
Old Nov 21, 2006 | 01:33 PM
dynamicS's Avatar
The reason I pick apart these products is because everyone is buying into this snake oil racing parts, and the 3 second drop in 1/4 mile time is NOT proven. I haven't seen it done on a XF. And that video he posted of the Altima is not good enough proof, we never see him open the hood of the car before hitting the track. And who knows what other mods he's already done to the car.
Why are we wasting our time discussing this goofy supercharger setup? Why don't you guys purchase a Paxton supercharger and build up from there! They are proven equipment and are well built.
Also Thomas Knight doesn't have any specs or CFM numbers to back his claims. So until then this is all Snake oil racing!
BY all means, I wish you to prove me wrong, if you believe so strongly in this product. Bolt it on your XF and do some 1/4 mile testing.
But if I'm going to drop $3,000 I will be doing it with a product that has a track record. Good luck in your quest for more power.
Old Nov 21, 2006 | 01:56 PM
psuperti's Avatar
Sounds good, I forgot one more pic and this is all T. Knight gave me.
Old Nov 21, 2006 | 09:47 PM
  #38 (permalink)
x'ed's Avatar
did you read it yet? do you know that it was a third party test? do you have any idea what's going on? do you know that website is one of the most respected turbo commentators out there. do you know what it would cost to purchase a paxton supercharger and "build from there"? do you really know about cars or just say stuff other people have told you? if you have a problem with the thread, go talk about how awesome that throttle response this is that you returned. your pessimism is pretty annoying.
Old Nov 22, 2006 | 02:27 AM
  #39 (permalink)
MAYAman's Avatar
I have spoken to Thomas Knight about that alternator driven unit for my S2. There are no batteries for this unit. That is all.
Old Nov 22, 2006 | 02:46 AM
  #40 (permalink)
TiamoPhoto's Avatar
I am so confused.
I am thinking about moding my xfire but everytime I read these forums someone has swayed opinions. What I would like to know is, will this Thomas Knight be like the turbos that I hear from other cars that give that hiss sound from the bypass? For some reason I love that sound and would be happy if this setup could do that as well:
I am looking into other mods, like ECU chips, ect... but would like to have this turbo installed first before getting any mods.
Thanks for those that contribute to us novice peeps.
AJ
