Looking in to buying, hard first gear?
Old Nov 29, 2006 | 02:21 PM
Alexander's Avatar
Post Looking in to buying, hard first gear?
Hi all, I'm hoping to join the Crossfire community and have been looking at a white 2004 with 31k miles for $18k.
The car feels good when test driving, but pushing it in to first gear is very hard and doesn't feel half like shifting in to any of the other gears, is this normal and will it be okay? Also when at idle I try to lift up the rear spoiler, and goes and stops about 3 times before fully deploying, but when I retract it, it comes back down smoothly without stopping, is this normal?
Thanks.
Old Nov 29, 2006 | 02:26 PM
nox1s's Avatar
Default Re: Looking in to buying, hard first gear?
Are you dead set on buying a white one? Or a stick?
I saw a 2005 Aero Blue Limited Automatic for $22k on ebay, it was brand new (200 miles?).
I'm not sure about sticks, since mine is an automatic. But if you idle and you try to deploy the spoiler, it should stop, but only for less then a second and it'll continue to go up.
You can even get an SRT-6 for 24-26k now. Sheesh.
I'm not sure what your budget is, but it doesn't sound like you're getting a steal. It's a good deal, but nothing to die over. If you just wait a little bit, i'm sure you can get one hell of a deal, especially with winter coming up.
Old Nov 29, 2006 | 02:54 PM
Aero Blue's Avatar
Help out our community and check out the classifieds.
Old Nov 29, 2006 | 03:08 PM
HDDP's Avatar
Thanks.
2004 w/31k ... don't pay more than $16,500 it was probably a lease turn-in with a payoff of $17,000...
Old Nov 29, 2006 | 05:13 PM
dynamicS's Avatar
Thanks.
They are hard to shift into gear when cold usually reverse is a bit stubborn, drive the car for about 5 miles and it will loosen up. Some require the TSB updates on the early 6 speed cars built in 2003, which the dealers are very lazy about doing. Make sure the car you purchase has had all the TSB updates done before buying the car. Otherwise move on to another car.
manually moving the spoiler up and down is a bit goofy, if you deploy it just tap the spoiler button a couple times to change the angle, and if you want it closed hold the spoiler button for 7 sec, until it beeps. and if your rolling above 58 mph you can't close it until about 55 mph, otherwise just pop out the spoiler fuse if it bothers you.
Old Nov 29, 2006 | 05:20 PM
Emthusiast's Avatar
17K is an OK price. Go for the SRT6 if you have the extra $. It is definitely worth it (price is mid 20's these days).
Kodebuster
Nov 5, 2020 04:06 PM
Cuda56
Aug 11, 2015 12:11 PM
Buchacho
Aug 6, 2015 12:48 AM
maxcichon
Jul 31, 2015 11:34 AM
XFIRED-TX
Jul 14, 2015 10:48 PM
