Few Current Problems **need Help Asap**
Old Dec 4, 2006 | 04:42 PM
CrossfireMan1999's Avatar
Default Few Current Problems **need Help Asap**
1. I installed HID lights and now the drivers side is out along with my drivers side fog light. Whats the solution? Could it be the kit to make both go out? And how do i get the HID light fixed? or does it have to be totally replaced?
2. My alternator just went (i guess) because at first i thought it was my battery (because the battery light came on the day before it went) so i got a jump and as soon as the person gave me the jump disconnected their car my car cut off. Could the HID kit have drained my alternator?
3. My car shakes when i hit drive it most of the time, I had needed new motor mounts because I am such a hard driver, could this be the reason of the shaking because i looked under the hood and pressed the gas and the Engine JUMPED, this is the same thing that happened before, so i guess new motor mounts will stop the shaking? Yes or no?
4. Alot of lights are on, on my dash, the check engine light (common so the dealer would say) the passenger side airbag (because the person trying to install my lambo doors was an idiot and actually couldn't do it so he put the doors back on and the passenger airbag light is on) Out front light indicator (From the installation of the HID kit). SOMEONE ANSWER MY QUESTIONS IF YOU CAN. IT WILL BE GREATLY APPRECIATED BECAUSE I AM LOOKING INTO GETTING A NEW ALTERNATOR AND MOTOR MOUNTS ASAP!
Old Dec 4, 2006 | 06:05 PM
bobs's Avatar
Default Re: Few Current Problems **need Help Asap**
*blink* I don't even know where to start...
Crossfireman, It sounds like you have a major electrical problem. Yours is the first I've heard of an alternator & motor mounts going bad.
Check the wiring on your HID installation.
Take your car to the dealer and have them read the OBD trouble codes & check the motor mounts.
Check your passenger airbag switch. Your lambo door guy probably switched it off or pulled the wiring out of the switch.
KwehCat
Aug 5, 2021 11:46 PM
xfireohio
Jul 20, 2020 12:03 AM
massanu
18
Nov 23, 2015 08:52 AM
stlas69
Sep 3, 2015 10:28 AM
gtjl
17
Jul 22, 2015 06:28 PM
