Man Running
Old Jan 4, 2007 | 12:09 PM
SteveM's Avatar
Default Man Running
I am trying to find out if anyone has info on the Icon of a man running followed by numbers. It occurs briefly in the odometer when you start the car. I now this sounds stupid, but I can't find anything in the owner's manual.
Old Jan 4, 2007 | 12:26 PM
spensley's Avatar
Default Re: Man Running
I think the 'Man' you're referring to is a 'wrench' or 2 wrench symbols.
Is the number following the symbol something like 300? (example - like mine), it means you have that many miles until the next service.
1 wrench = service A
2 wrenches = service B
See the manual, or search the forum for what needs servicing.
msheredy's Avatar
Try to take a picture of the icon and post it on here. That way we can see what you are seeing.
Old Jan 4, 2007 | 04:46 PM
Maxwell's Avatar
I've never seen the man running before, I have seen the wrenches and the oil bottle that tells you how much oil is in the engine case.
Old Jan 4, 2007 | 05:39 PM
raulito11
Guest
Posts: n/a
Funny that you mention it but I think I found your running man which was recently on a trip to Mexico on a stop light...Not like here in the states were we have WALK and DON'T WALK, in Mexico for the pedestrians they have a green man walking with a timer counting down...as the timer counts down the little green man walk faster and faster then finally running...I thought it was pretty hilarious when I saw this, too bad I didn't get a chance for a pic or video for that matter...No running man on the xfire only wrenches...
Old Jan 5, 2007 | 10:09 AM
SteveM's Avatar
Thanks spensley for the quick reply! My mistake. You were right. Blame it on bad eye sight and an over active imagination. Glad I was able to provide a bit of humor to some of you.
Old Jan 5, 2007 | 12:55 PM
HDDP's Avatar
This is part of the personal functions computer. It's telling you that you better hurry-up and get your butt to work.
Old Jan 6, 2007 | 09:05 PM
vetofunk's Avatar
I just noticed the 2 wrenches today. It shows the two wrenches and then 1,100. Does that mean 1,100 miles until I need an oil change and Service B?
I just plan on taking my car in because I have the rattle from the trunk and my brakes seem to be grinding already...and I only have 11,000 miles!?
Old Jan 7, 2007 | 01:02 AM
nascarhq's Avatar
ah, the running man, it means you just activated the self destruct mode.
Old Jan 7, 2007 | 06:23 AM
bobs's Avatar
That would be correct.
Old Jan 7, 2007 | 08:50 AM
marauderroy's Avatar
The Running Man,
Your car needs some love from you. You need to wash and wax your XF asap or Richard Dawson will show up and strap you into a tube and shoot you off to the bad place (dealership service waiting room) where you will get the run around.
Old Jan 7, 2007 | 02:43 PM
HDDP's Avatar
Ah yes... the secret "self destruct mode"... I forgot about that... The running man means "quick, run away before the car explodes".
Old Jan 15, 2007 | 09:31 PM
Fupa13's Avatar
Just curious, can you "clear" the notification from the odometer, or is it a "dealer only" thing ?
Old Jan 16, 2007 | 06:30 AM
bobs's Avatar
What your seeing is called the "flexible service system" indicator, or FSS. Do a search on this forum. The procedure has been discussed and posted several times before.
roar
Jun 15, 2022 11:46 AM
Nov 11, 2015 05:22 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
amx1397
Oct 2, 2015 05:20 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
