Start Engine button...
Old Apr 12, 2007 | 10:01 AM
slimjimd's Avatar
Default Start Engine button...
I seen this on You Tube, is the Start Engine button an option you could have gotten with the XF, or did this guy custom install one. Either way, it is cool and I've gotta get one.
http://www.youtube.com/watch?v=D-K9z...related&search=
Old Apr 12, 2007 | 11:53 AM
Maxwell's Avatar
Default Re: Start Engine button...
If he was really smart he would have wired up the emergency triangle into a start engine button, now that would be cool and stealthy.
Old Apr 12, 2007 | 12:04 PM
maxxm's Avatar
Excellent suggestion, but probably lacks the bling factor the guy was looking for.
Old Apr 12, 2007 | 12:28 PM
slimjimd's Avatar
Regardless of the "Bling" factor, using the Hazard button could cause a problem. What if, in an unfortunate situation, you are needing to use your Hazards, then what?
Old Apr 12, 2007 | 01:27 PM
RPM's Avatar
RPM
Moderator
Shouldn't be too hard of a mod to do. I don't really see the point myself since you have to use a key and turn it anyway - and then press the button (like in the s2000).
Old Apr 12, 2007 | 03:04 PM
former NXMX5's Avatar
had this one in my Miata... not sure if this kit comes with a relay, but you'll need one.
http://www.autotoyaz.com/enstpubu.html
Old Apr 12, 2007 | 03:22 PM
slimjimd's Avatar
Looks easy enough to install, thanks for the info. On your Miata, were you still able to start the car by turning the key, or does this disable the car from being started with a key?
Old Apr 16, 2007 | 03:16 PM
MAYAman's Avatar
Yeah but you still have to put the key and turn, thats corny. If it were just a button then we'd be talkin.
Old Apr 16, 2007 | 03:35 PM
old man's Avatar
this is standard on the viper trucks.
Old May 14, 2007 | 03:53 PM
Goldwing's Avatar
If you convert your hazard button into a "start button", then you need to convert the "unlock door" switch to a hazard button. Then convert...
Or you can get that big red "GO" button from Staples and stick it on the top of the dashboard. It makes a dandy anti-theft deterrent, too.
skeet370
May 15, 2018 12:57 PM
wruss
Feb 8, 2017 01:05 PM
northwest_crossfire
May 30, 2016 05:19 PM
Jul 29, 2015 06:13 PM
TOPLA
Jul 14, 2015 07:46 AM
