Trunk wouldn't unlock!!
Old May 22, 2007 | 05:57 PM
jonathan's Avatar
Default Trunk wouldn't unlock!!
Twice in the last week, while my wife was using her '05 Roadster, she put the top down and drove to work, after shutting the car off, tried to unlock the trunk to get her gym bag out and the trunk would not unlock? Later when she got home and tried to unlock the trunk no problem.
Anyone else ever have this problem?
Old May 22, 2007 | 06:55 PM
DanielNTX's Avatar
Default Re: Trunk wouldn't unlock!!
Maybe there was a kink in the vacuum line that releases the lock.
Old May 23, 2007 | 11:42 PM
apkano's Avatar
Life is random...so am I.
I have experienced this problem also. Usually if I hit the unlock twice on the keyfob the trunk unlocks. Every once in a while it fails to work though... I have found that if you push down on the trunk a little (read...forcefully!) and hit the unlock button another 2 times it usually works fine.
It's annoying as hell...but not enough so that I want to give the car up to the dealer for god only knows how long!
If you do have this problem repaired I'd be interested in knowing what the fix/problem was!
Osusannah
Feb 12, 2024 01:49 PM
o55ie18
Oct 5, 2015 05:50 PM
Selbyl
Sep 26, 2015 04:15 AM
rmcdaniel12
Sep 22, 2015 01:20 PM
xjken
Sep 13, 2015 10:18 PM
