Sprint Booster installation problem thread
Old Sep 17, 2007 | 06:42 PM
XFireHammer's Avatar
Default Re: Sprint Booster installation problem thread
Originally Posted by Guy III
I could not remove the console side panel. Someone must have superglued that #*@! screw in place - and not being metal, it stripped right out. Re the washer, magnets did not work (tried using two). It took dental probes - the kind with bent tips - and a lot of time to work them under the washer and lever it out. BTW, I had a very experienced mechanic friend with me working on this so it was not just my fumble fingers...
One suggestion - once the washer is out, use a power drill to carefully resize the hole. Just a slight reaming will do it - enough so that the washer can perform its design function but enough so that it will not bind against the center pin the next time you might want to remove it.
Guy
Interesting... The hardest thing for me was fitting my upper body into that small foot area to plug in the SB! And I really did not have a hard time plugging the SB in, as some have mentioned as being another problem.
Isn't something; a thing so small can cause so many problems, yet once installed and functional, generates a smile on most people faces!
XFH
KDW4Him
18
Sep 1, 2021 05:47 PM
waldig
Jul 31, 2017 09:46 AM
Aug 11, 2015 05:19 PM
gtjl
17
Jul 22, 2015 06:28 PM
mike28117
Jul 17, 2015 01:59 PM
