Need help - Wiring problem.
Old Dec 26, 2007 | 01:42 PM
jackei's Avatar
Default Need help - Wiring problem.
I'm working on a project to set a back up camera under the rear end of the car (next the metal hook to be exact, which I tested to have a very good camera view, and the camera will be invisible from others)
Does anyone knows which is the easiest way to hook up to the 12-volts source for my camera at such location?
My plan was to lead the wire from under the car (through the open space at the metal hook) into the trunk. I removed the covers inside the trunk, but have no clue which way should I go. Thanks for your help.
Old Dec 26, 2007 | 01:51 PM
MMZ_TimeLord's Avatar
Default Re: Need help - Wiring problem.
Go to this thread and check some of the pictures of the BARE crossfire chassis. That should help you with 'places' to take the wires inside.
I personally would recommend using one of the 'spare' fuse positions in the underhood fuse block or tie it into the heated seat hot in the center console with a small in line fuse for the camera circuit.
Hope that helps... Cheers!
Old Dec 26, 2007 | 02:46 PM
jackei's Avatar
So how do I connect from the underhood fuse box back into the cabin?
Old Dec 26, 2007 | 02:57 PM
You will probably have to follow the factory wiring. Someone on the forums did something similar to power a device in the cabin, but I don't remember where he took it through.
I would check the bulkhead just inside of one of the underhood fuse boxes and see if there is a place (grommet) that you can pass a new wire through.
The other option is like I said... tap the hot on the heated seat circuit. The device you are running is probably VERY low amperage anyway, so it won't be a big load. That's what I did for my inverter.
Hope that helps... if not... check through the service manual schematics, take a picture or two and ask again... I'll try and see where you could go through, but I'm at work right now.
Old Dec 26, 2007 | 05:25 PM
calxfire's Avatar
If it's low wattage how about tapping the backup lights that way the camera is turned on everytime you put the car in reverse?
Old Dec 26, 2007 | 05:31 PM
robby363's Avatar
I hooked up mine that way works great with no problems.
Old Dec 26, 2007 | 06:53 PM
jackei's Avatar
Yea... I guess I'm going to connect both the camera and monitor to the backup light. Hope it won't overload it.
There are 2 black and 1 brown wire to the backup light(right side), I believe the black is ground and the brown is hot. Correct me if I'm wrong. Thanks.
Old Dec 26, 2007 | 06:58 PM
apkano's Avatar
Life is random...so am I.
A trick you may want to use, if you have a voltmeter/multimeter, is to hook one of your leads up to a thin sewing needle. That way you can just pierce through the wire without a lot of hassle. Just be sure to re seal the hole you made with a little dab of silicone sealant!
I mean the hole in the wire.....not your finger!
Sep 28, 2015 07:40 PM
Abaton6
Sep 24, 2015 10:14 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
bobbie
Sep 12, 2015 12:49 PM
RiderJC
Sep 7, 2015 11:19 PM
