Running Lean?
Old Jun 2, 2008 | 08:48 PM
Fino's Avatar
Default Running Lean?
I've been reading some conflicting information about adding an exhaust and/or a CAI. Some have said it will cause you to run lean. This would then cause the need for new injectors and an upgraded ECU. That sounded a bit over kill to me for just swapping out the exhaust. In my car experience, with only one exception, there were no negative side effects when a car of mine had new exhaust added to it. However, I am not counting the neighbors complaints about the noise
Is there anyone out there with only a CAI or Magnaflow exhaust that has experienced pinging or any other problems? Let me know either way.
Thanks,
Old Jun 3, 2008 | 04:47 AM
TVT_DESIGN
Guest
Posts: n/a
Default Re: Running Lean?
The lean condition is found on N/A cars, which you have. It's caused by en ECU flash and CAI, adding a free flowing exhaust adds to the lean condition. Freeing up exhaust flow will lean out any engine.
roar
Jun 15, 2022 11:46 AM
Nov 11, 2015 05:22 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
cjw
Oct 26, 2015 10:26 PM
amx1397
Oct 2, 2015 05:20 PM
