Oil Level Indicator Question
Old Jul 31, 2003 | 04:24 PM
X-fired's Avatar
Default Oil Level Indicator Question
I can't get the in-dash oil level to indicate - following the instructions in the manual. I only get the single wrench icon and the miles to go.
Any problems? Any tips?
Old Aug 25, 2003 | 05:08 PM
X-fired's Avatar
Default
Hello.... anybody?
Old Aug 25, 2003 | 09:22 PM
mls's Avatar
mls
Default
I was able to get the oil level to display. I had to hold down the indicator to get it to light up.
Old Aug 25, 2003 | 10:11 PM
X-fired's Avatar
Default
MLS - can you give more details? What indicator did you hold down?
Old Aug 26, 2003 | 08:37 AM
mls's Avatar
mls
Default
The reset for the trip odometer.
Old Aug 26, 2003 | 09:23 AM
texex91's Avatar
Default
Yep, mine worked doing the same thing mls.
Old Aug 28, 2003 | 06:55 PM
RUReady's Avatar
Default
When engine is off, turn ignition to RUN, do not start.
Wait until the Oil Can symbol appears in the Trip Odometer display and the Clock symbol appears in the Odometer display - this may take 5 seconds or so. Then press the Trip Odometer reset twice and the oil level indication will appear in the Odometer display.
The Owners Manula doesn't make it clear that you have to wait a few seconds before the Oil Can and Clock appear before you can press the Trip Odometer reset twice.
If you press the reset more than twice, then 1 wrench will appear with the mileage remaining before A Service is required or 2 wrenches with the mileage before B service.
Old Aug 29, 2003 | 09:15 AM
X-fired's Avatar
Default
Thanks, RU. That's the info I needed.
Old Sep 13, 2003 | 08:51 PM
TP150's Avatar
Default Oil level indicator
Make sure your oil is warmed up or it will not work. The book says to warm the engine up first. I thought mine didn't work. Finally I warmed the engine up an it worked fine. If all else fails read the instrunctions.
Old Sep 14, 2003 | 12:03 AM
X-fired's Avatar
Default
I read the instructions - it was the 5 second delay I wasn't waiting for.
xfClifford
Mar 3, 2021 04:52 PM
xfireohio
Jul 20, 2020 12:03 AM
sittininthesun
Aug 24, 2015 10:47 AM
toob
Aug 19, 2015 07:31 AM
skeet370
Jul 18, 2015 01:02 PM
