Squeaky Rear End >>FIXED!!<<
Old Sep 5, 2003 | 04:28 PM
texex91's Avatar
Default Squeaky Rear End >>FIXED!!<<
Okay, I found out what the 'big mystery' is with the rattle in the back. Just returned from the dealer (who fixed mine).
It's the rear lift gate. What is making it happen is that the black 'holders/hatch stops' (look like foam pieces) on each side of the liftgate NEED TO BE ADJUSTED. If you go and look at yours, you will notice that you can move them 'up/down' with a allen wrench (I think that's what the nut is). Mine were all the way to the top, which caused the back latch itself to rattle, because there was not enough 'tension' between it and the liftgate. Wha la--it is fixed! This is really something the dealer needed to do at delivery (hence the reason mine has been 'rattleing' since day one.)
So for those that are 'rattling' in the back this is your problem. If you have any questions let me know. My car sounds soooo solid and tight now--one happy camper now!! :lol:
Old Sep 5, 2003 | 05:17 PM
crossfiretech's Avatar
Default
Congrats,I had a feeling it was something with the hatch stops.
Old Sep 5, 2003 | 09:02 PM
jimbo257's Avatar
Default
Great to hear yours is fixed and it was an easy problem to cure. I'll be sure to have mine checked out. Still waiting for rear end parts. I'll have them check the hatch when I take mine in for the other repairs. Thanks.
Old Sep 6, 2003 | 12:05 AM
PeterG's Avatar
Default
Tenex THANKS for the report I will try to fix mine tomorrow and see what happens
Old Sep 6, 2003 | 08:54 PM
PeterG's Avatar
Default
Adjusted the foam pads on the rear hatch ( they are along the curve of the hatch) and the rattole went away! Thanks Texex
Old Sep 7, 2003 | 07:43 AM
sambo13's Avatar
Default
Thanks TEXEX, I'm going to look at mine today.
Old Nov 25, 2003 | 09:20 PM
Gailwrath's Avatar
Default
Dont let that rattle go on for to long or you may find a ding in the paint where the hatch has been hitting the body.
Old Dec 6, 2003 | 10:15 AM
pete1365's Avatar
Default
Excellent. Fixed mine too.
Thanks
Old Dec 30, 2003 | 03:23 PM
joost's Avatar
Default
Excellent, I just made an appt with the dealer for this. I'll check it out and maybe save me a day with out the car.
Old Jan 2, 2004 | 05:11 AM
98intrigue's Avatar
Default
awesom! thanks for the news texex91 :wink: . my dad has been complaining about the same problem with his rear lift gate. this will make him quite happy.
Old Feb 6, 2004 | 01:42 AM
Paul V's Avatar
Default
I experience same problem, rattle coming from the rear, at a high speed. Where should the foam pads be positioned on the tailgate? The Middle? Towards the bottom?
Paul V
Old Feb 7, 2004 | 02:53 PM
AZ Outlaws's Avatar
Default
Paul V
I didn't see any "foam" stops unless I'm missing something. There are two "rubber" stops, one on each side of the hatch at the bottom. They can be adjusted up and down about  inch.
amx1397
Jan 24, 2016 02:12 PM
stlas69
Sep 3, 2015 10:28 AM
hhr hellshotrod
Aug 17, 2015 11:27 PM
BrenLW
Aug 5, 2015 04:53 AM
55chevy
Jul 20, 2015 03:08 PM
