turbo and wing question
Old Nov 12, 2003 | 09:44 PM
wilmingtonwiggle's Avatar
Default turbo and wing question
i wanna know when somebody is gonna come out with a turbo for the xfire and how much its gonna cost. and i also wanna ask if andbody knows how much drag the wing reduces or what other effects it may have such as keeping the rear wheels on the ground and stuff like that. hit me back plz
Old Nov 12, 2003 | 10:10 PM
imported_mightyjlr
Guest
Posts: n/a
Default
The wing doesn't reduce any drag, it increases it. It helps keep the rear wheels on the ground. As for a turbo, no turbos yet, I don't know if we'll ever see a turbo, but there are superchargers available for it right now. Expect to pay lots of money though.
Old Nov 12, 2003 | 10:14 PM
kusheen
Guest
Posts: n/a
Default info
The rear wing provides about 80 lbs of downforce. I believe it also breaks up a great deal of turbulence caused by the less than aerodynamic shape of the car. Remember, the tear drop, with the cab forward profile, has generally been seen as the most aerodynamic design. The Crossfire is the polar opposite. If you look at the rear end, it's very reminiscent of the Chevy Cheetah Sports Racer of the 60's, designed to try to run with the 427 Cobra. It was generally considered to be an aero brick.
In other words, the car needs the wing, it's not cosmetic.
As for a turbo, Renn Tech can hook you up with a Supercharger. Got some cash burning a hole in your pocket? Willing to write off the factory warranty?
I suppose one could try to find a rear ended SLK Kompressor and move the mechanicals over to the Crossfire.
Old Nov 13, 2003 | 02:29 PM
Brian's Avatar
Default
The down force is 40lbs approx
Old Nov 13, 2003 | 04:41 PM
WesMichaels's Avatar
Default
That's 40 lbs of downforce @ 60 - 70 mph. The downforce is greater @ higher speeds.
Old Nov 13, 2003 | 06:31 PM
kusheen
Guest
Posts: n/a
Default downforce?
Downforce is 40 lbs? Mmm...I read somewhere it was 80. Will try to find the source.
Old Nov 13, 2003 | 08:05 PM
crossfiretech's Avatar
Default
I believe the service manual says 40lbs. at 80 mph.
Old Nov 13, 2003 | 09:50 PM
Default
Even if it's 40 lbs at 80 mph it's greater at greater speads. I'm an aeronautical engineer and I can figure out the rest. As a manager for Boeing in the Langley area I think I will see what they will charge me to run some tests on my crossfire.
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
