Car cranks but won't fire, but eventually will
Old Sep 4, 2010 | 01:02 PM
blkXfire04's Avatar
Exclamation Car cranks but won't fire, but eventually will
My 04 crossfire has just recently started with this problem, it will continue to crank even when I am not touching the key, but will not fire. Then once it fires it runs fine but the check engine light comes on. 1st time it happened I thought it was the key fob so I replaced the batteries. It has done it 2 times since and usually after I have driven even a short distance and shut it off then 10 min later it wont fire, but then does in a few mins. Any IDEAS???
Old Sep 4, 2010 | 02:14 PM
kingkub57's Avatar
Default Re: Car cranks but won't fire, but eventually will
Normall for the starter to stay engaged for a few seconds, but cranks and no fire is most likely the CPS (crank shaft sensor) search the threads, fairly cheap to get and easy to replace.
Old Sep 4, 2010 | 03:49 PM
It will crank only as long as you turn the key on manual transmissions.
Old Sep 4, 2010 | 06:07 PM
antonio311's Avatar
When you turn the key to start it, the car will keep cranking even when you let go of the key, this is normal & some crossfires do this. i have 2, one does this the other doesn't & it's totally normal. You can have the dealer fix this theres a TSB if it annoys you. It doesn't annoy me anymore.
As for not starting and long cranking times before starting, check the Fuel pump. As mine also had this problem & the Fuel pump needed to be replaced & now its starts right up.
Old Sep 4, 2010 | 06:39 PM
tighed1's Avatar
King got it.
https://www.crossfireforum.org/forum...on-sensor.html
Old Sep 4, 2010 | 09:54 PM
Originally Posted by tighed1
2 for the King....
Old Sep 5, 2010 | 06:07 PM
blkXfire04's Avatar
Thumbs up Re: Car cranks but won't fire, but eventually will
Well I just ordered the Crankshaft Position Sensor for my car, I hope this fixes the problem. I'm a chick, think I can replace it myself? Thanks everyone for your help again!
Old Sep 5, 2010 | 06:08 PM
I'll bet you can! It really is easy, so they say.
Old Sep 5, 2010 | 09:14 PM
tighed1's Avatar
So is changing yer oil! So they say!
Old Sep 6, 2010 | 09:32 AM
blkXfire04's Avatar
So, what I'm hearing is ....get the part, and have a mechanic put it in?
Old Sep 6, 2010 | 10:02 AM
If you can get the connector of the unit and have the tool to unscrew the little bolt you should be able to do it for yourself. You want an E8 socket.
If you have a mechanically inclined friend who owes you a favor, get him/her to do it for you.
Good luck.
Old Sep 7, 2010 | 09:21 AM
tunaglove's Avatar
Check valve in fuel pump gets stuck open. Fuel line loses pressure and vapor locks.
Old Sep 7, 2010 | 09:47 AM
I sure hope I can live that down, someday. I know the financial cost is still hanging over my head - haven't replaced the truck yet.
So, don't be working on your car when going thru a divorce - THAT is the lesson.
ingsoc39
Nov 25, 2019 05:44 PM
mhajek18
Dec 30, 2015 03:40 PM
Archaic
Jun 30, 2015 06:33 PM
carmax
Jun 18, 2015 01:30 PM
blackpepper
16
Jun 2, 2015 12:50 PM
