Question about Fan control (Blower)
Old Dec 27, 2010 | 02:19 PM
Jersinger's Avatar
Default Question about Fan control (Blower)
[FONT='Tahoma','sans-serif']I am experiencing the weirdest thing with my fan control (blower). When I start my car the heater fan does NOT start up. If I drive at lower speeds, it still does NOT start. Once I get to higher speeds, the fan start. It creeps its way up to full speed and then eventually it runs normal.[/FONT]
[FONT='Tahoma','sans-serif']I checked for bad fuses, loose wires and shorts, but everything checks out. Can anyone offer some insight into this issue? Similar issue? [/FONT]
Old Jan 12, 2011 | 12:06 PM
green-ghost's Avatar
Default Re: Question about Fan control (Blower)
do you have it turned up high? I just replaced the blower motor resistor on my 01 sentra, it went bad and had only one speed, full blast
Old Jan 12, 2011 | 12:25 PM
Jersinger's Avatar
Hi Green.....
[FONT='Tahoma','sans-serif']It's kind of weird. There is heat but the fan is intermittent. It mostly comes on when I drive fast. After a while of stop and go traffic, the fan stops again.[/FONT]
[FONT='Tahoma','sans-serif']I know about the resistor issue, and it's really common in GM's. This is weird and I am about to SPEND the big bucks at the dealer. [/FONT]
Old Jan 13, 2011 | 07:55 AM
eruby's Avatar
my fan is flakey too. i usually leave it on low-med but sometimes (very random) it has a mind of it's own. i took it to the stealer while still under warranty - they said they could not duplicate it and they checked the resistor and it checked ok. now out of warranty. anybody know how to change this resister? cost?
Old Jan 13, 2011 | 12:25 PM
edgehead2000's Avatar
I think you're looking for this forum post:
https://www.crossfireforum.org/forum...where-get.html
I am having all the same issues and hope that buying a new the resistor fixes all my issues.
Old Jan 28, 2011 | 01:27 AM
loosecannonxf's Avatar
Because my fan malfunctioned intermittently, my dealer told me to bring it in immediately as soon as it messed up again. I did, and they were able to diagnose it right away. They replaced the whole fan control under warranty. No problems since.
waldig
Sep 2, 2015 11:02 AM
bullspc5
Aug 20, 2015 10:03 PM
ldare2000
Aug 17, 2015 09:41 AM
mthtulsa
Aug 3, 2015 06:14 PM
waldig
Jul 15, 2015 02:05 PM
