Can't remove trunk liner-roadster
Old Jan 21, 2011 | 03:03 PM
rboineau's Avatar
Default Can't remove trunk liner-roadster
Roadster/convertible model.
Trying to help a neighbor lady with a burned out brake light, I was not able to remove the trunk's inside panel on the right. All the little push-pin fasteners came out, but that still left a steel post topside holding the liner. I assume this post and its twin on the other side are anchors for a cargo net or some such but I could not tell if it is screwed into the metal, bolted/nutted on the back side (which I cannot see or access), or how it is retained. Didn't want to force/mar it, nor did I want to damage the liner by trying to pull it out from underneath the post. Any help/advice would be appreciated.
I did get the bulb replaced but had to climb inside the trunk, contort my aging body into a position it still has not recovered from, reach over the loosened liner and--barely--get my hand far enough in there to change the bulb. Seemed to do the trick, but I'm still not sure the bulb is fully seated in the socket. If I could have fully removed the liner it would have been much easier.
Old Jan 21, 2011 | 04:23 PM
brian_omeara07's Avatar
Default Re: Can't remove trunk liner-roadster
Hey there, that's super nice of you to help her out Actually you made it far too difficult. There's a piece of hard "fabric" (seems to be cardboard backed) that simplly slides out from where the carpet meets the vinyl top part of the roof. At least on the coupes, if this is a roadster I wouldn't know.
Old Jan 21, 2011 | 07:34 PM
It's a roadster the title says so.
I thought you reached around the liner to get to it.
Old Jan 23, 2011 | 02:45 PM
rboineau's Avatar
Surely others have had to change the tail-light/brake-light bulb in a ROADSTER/CONVERTIBLE.
Yes, as I said in my original post, it is indeed possible to change the bulb without completely removing the side liner(s) but if I have to do it again in the future I would certainly like to be able to get that post/anchor off and take the liner all the way out. That way I can avoid being half-crippled for the next two days as my body tries to regain the shape it had before wedging myself in that tiny trunk and forcing my arm and shoulder to bend in ways nature never intended.
Why the designers couldn't have provided better access I don't know, but if I had ten cents for every bad word I said while doing the job, I could buy a nice handgun.
Old Jan 23, 2011 | 02:56 PM
Kane's Avatar
Banned
An easier way (I've heard) is to raise the top and stop it when the tonneau panel is vertical. Access the taillight from above. Ta da.
Let us know if that really is a 'better' way.
Old Jul 12, 2013 | 07:04 PM
Cgers's Avatar
Sorry for the 2 posts my internet is lame.
I have another question guys.. When i removed the trunk coating i saw that some of the push type and tree type screws where broken or missing.. Does somebody know where i can buy a set of the right sizes? And can buy it with paypal and send it to the netherlands?
Old Jul 12, 2013 | 09:42 PM
This LOOKS like the correct fastener, but you never know ....
( and they ship to the Netherlands ! )
100 Pcs New Air Baffle To Under Carriage Clip Retainer Replace GM 21030249 Chrysler 6503598 Ford N807389S Saturn 2 Door & 4 Door-in Auto Fastener & Clip from Automobiles & Motorcycles on Aliexpress.com
Old Jul 12, 2013 | 11:18 PM
Try this post and try the link in red they appear to be the part.
CLICK
OR"><span style=OR" /> OR">OR
OR
Search this number, Mercedes #201-990-02-92 .
syfi
Mar 28, 2026 04:14 PM
Osusannah
Feb 12, 2024 01:49 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
