Shell Rotella T6 Full Synthetic
Old Feb 11, 2011 | 06:08 PM
Erichenderson02's Avatar
Default Shell Rotella T6 Full Synthetic
Has anyone used Shell Rotella T6 Full Synthetic oil in their Crossfire? I recently purchased my car from a dealership, so I assume it has 0w-40 in it. I wanted to make the switch to 5w-40, and Shell Rotella seems to a lot cheaper as opposed to Mobil-1.
It says it meets MB approval for the 228.31 specification...
I'm not quite sure what the specs are for our engines?
Help please!
Old Feb 12, 2011 | 12:39 AM
astrnmrtom's Avatar
Default Re: Shell Rotella T6 Full Synthetic
Been running it in my 04 since my last oil change in December but that's the extent of my experience with the oil. Odds are I'll continue to use it unless I come across some compelling reason to stop. If it meets the specs, and saves me a few buck while doing so, that's good enough for me!
Tom
Old Feb 12, 2011 | 02:56 PM
awilson40's Avatar
My Dad was a member of one of the top Sprint car teams in the country, his crew chief ( USAC crew chief of the year) swears by Rotella and I ran it for years in my Porsche turbo with never an issue.
Old Feb 12, 2011 | 03:23 PM
Thanks for the replies guys.
Sounds good to me
Old Feb 12, 2011 | 03:49 PM
downwardspiral's Avatar
That's not the right spec, 229.31 is different than 229.3 and it doesn't show up on the 229.3 or 5 lists.
The spec lists are on page 3 of this thread:
https://www.crossfireforum.org/forum...il-deal-3.html
From the manual:
For best performance and maximum protection under all
types of operating conditions, only use synthetic engine
oils, approved to MB 229.3 or MB 229.5, such as Mobil 1
SAE 0W-40.
Old Feb 13, 2011 | 10:55 PM
rekcah's Avatar
If you can wait, there are deals for mobil1 every now and then. Like $4-5 per quart, just stock up then. I still have enough for 3 oil changes from the last Mobil1 Deal.
You could also use what the dealership uses which isn't mobil1.
Look at attached pdf
File Type: pdf
Old Feb 14, 2011 | 12:20 AM
Hindin's Avatar
Not sure but I believe Rotella T6 Full Synthetic is approved for diesel burning MB's and as pointed out previously our Crossfire spec number differs just a bit. As a side note a lot of motorcycle riders use Rotella T6 because of the higher ash and zinc content.
Old Feb 14, 2011 | 10:20 AM
From the manual:
SAE 0W-40.
Oil is cheap at any price
, engines are not.
Old Feb 14, 2011 | 10:37 AM
Help please!
As stated earlier in this thread, the MB 228.31 grade oil was for diesel engines. More importantly, MB specified this grade of oil for commercial vehicles with diesel engines that had diesel particulate filters installed. The MB spec for passenger cars with diesel engines is a different designation.
Old Feb 15, 2011 | 01:57 PM
Ed Mahoney's Avatar
So what are you paying for the shell oil ????
Old Feb 16, 2011 | 04:39 AM
It's about $23 a gallon. Haven't checked at Walmart (I really need to), but hopefully it's even cheaper there.
Edit: A quick scan on google showed me a forum where guys are talking about 1 gallon of Shell Rotella T6 being $18.88
crymar
Sep 23, 2014 02:49 PM
Billerickydicky
U.K.
19
Jun 28, 2014 08:23 AM
sccarally
South Forum
Aug 18, 2013 07:14 PM
FTroopChief
Other Vehicles
Mar 5, 2011 07:42 PM
