Battery Dead. Should I expect any issues after replacing it?
Old Apr 11, 2011 | 06:39 PM
harbor's Avatar
Default Re: Battery Dead. Should I expect any issues after replacing it?
Originally Posted by JaneBridges
Well, just put a new battery in because we couldn't even jump it. I found one easily at Autozone in the right dimensions. Installed and took right off. No lights or alarms.
However, I have a feeling I lost my tune from Eurocharge. So what do I do now. Do I have to send the ECU up to Eurocharge?
Jane - The AutoZone battery fit exactly with no spacers, mods, etc? My orig Varta is on year 5, and I may be in the market soon.
Old Apr 11, 2011 | 07:02 PM
JaneBridges's Avatar
Jim: It fit perfectly. It was a Duralast. I specifically requested the same OEM dimensions. FAirly easy to install as my nonmechanic husband put it in for me. Car took right off. It cost $216.00.
I really didn't realize how heavy these batteries are.
Jane
Old Apr 11, 2011 | 07:24 PM
harbor's Avatar
Jane - Got it. Thanks.
Looks like Johnson Controls makes Varta, Duralast and a few others.
Old Apr 11, 2011 | 07:27 PM
Jane glad to hear you got it taken care of. I hope that is a good battery, it is over twice the price of a good Interstate battery that will fit in the Crossfire. Be easy on the husband...
James
Jane
Old Apr 12, 2011 | 03:51 PM
Originally Posted by oledoc2u
You guys must have jinxed me, my shurikyn battery is dead, and it had a maintainer on it. I drove it a few weeks ago without any problems, and now it won't hold a charge....Rob?......lol
I just bought one of these from Rob. I hope they are not problematic.....
Old Apr 12, 2011 | 04:01 PM
Well, FP, they are made for racing so to speak, so I didn't expect them to last the usual 4-5 yrs. The weight is very light compared to a full size battery. I put my regular charger on it, charged it back up, and then put my maintainer back on. She starts just fine now. It may have lost the ground from the maintainer. She's working now.
Old Apr 12, 2011 | 04:06 PM
thanks doc
Old Apr 14, 2011 | 02:09 PM
OK, need some help. I installed the new battery from Rob, but have no power, and doesn't even click when I turn the key. Any thoughts on what to look for?
Old Apr 14, 2011 | 05:21 PM
Larry Hitze's Avatar
FP, did you run a voltmeter across the battery termminals to see if it actually had any power to it? I would have that be the first step.
Was it shipped to you or did you pick it up? Batteries don't like to be dropped or banged around alot.
Old Apr 17, 2011 | 08:47 PM
Rob is sending me a new one. I think I got one that was DOA. In the meantime I was able to recharge my old battery off the car. It starts just fine now, but have the water coolant light on. I don't know if it will go away eventiually. My radio wont power on.
Have any of you had these sympoms as a result of a dead battery?
Old Apr 17, 2011 | 08:52 PM
the battery may have a dead cell in it FP. Keep in mind that little battery you are buying is for racing. It is for weight reduction. So, you will have to keep an eye on the shuryken, maybe run a maintainer like I do. These little batteries are a lot like a motorcycle battery. The can be contrary. Hopefully, the new battery will take care of your problems.
Old Apr 17, 2011 | 09:13 PM
Doc, I bought the shuryken for performance reasons. While I don't race, I want to keep weight off the car. That's why I even keep weight in mind when buying tires. My car is a daily driver from Spring to Fall, so I hope the lighter battery keeps the charge. For the winter maybe I'll pull it off and bring it down to my basement.
Old Apr 17, 2011 | 09:20 PM
The lighter battery will make up for the added weight of the SRT bumper and all the chrome
Old Apr 17, 2011 | 09:29 PM
Good one James, but so true. Got find how to make up for it.
Old Apr 17, 2011 | 10:46 PM
My battery went flat over the winter as a result of not running the car enough to keep it charged. It would not start the car (click, click, click) but the radio worked fine.
When it was charged the only light that was on was the ESP light and that was fixed by turning the steering wheel blah blah blah...
Check the radio fuse and coolant level sensor connector.
Old Apr 17, 2011 | 10:52 PM
Where is the coolant level connector?
Old Apr 17, 2011 | 10:57 PM
itsky's Avatar
Folks,
May this be a gentile reminder to drive your XF during the winter. If you cannot do so, may I suggest that you move to Colorado so that you can do those winter drives.
Old Apr 18, 2011 | 02:40 AM
  #38 (permalink)
At the bottom front of the reservoir.
Old Apr 18, 2011 | 07:31 AM
  #39 (permalink)
Thanks 180
Old Apr 18, 2011 | 07:42 AM
  #40 (permalink)
Originally Posted by itsky
Folks,
I do drive mine in the winter, 5 inches of snow is a little much though.
