window washer fluid sensor on when full
Old Aug 23, 2011 | 02:46 PM
gfolino's Avatar
Default window washer fluid sensor on when full
Hello, I just purchased an 05 crossfire which had a crack in the windows washer fluid reservoir. The sensor light was on as well due to no fluid in reservoir.. I replaced the reservoir and filled to the top (until overflowed) and the sensor light is still on? How do I correct the low fluid sensor light on my dashboard?
thank you!!!!
Old Aug 23, 2011 | 04:04 PM
Default Re: window washer fluid sensor on when full
thank you!!!!
I have not looked at this at all and I am only suggesting it could be the sensor not working properly. Would it be possible to remove the sensor and test it?
Does it work on a float principle? If so it could be stuck.
Old Sep 1, 2011 | 02:57 PM
user 8202's Avatar
Banned
+1 Been there, done that...(not on Crossfire)
Old Sep 1, 2011 | 05:05 PM
Squirrel Crusher's Avatar
The fluid sensor has a slight time delay hinged float switch. It will slip into the tanks rubber gromet in any position,but only one position is correct. Take's two people to verify this test unless you have a ohms meter. One in the car with the switch on watching the gauge. The other has the sensor pulled out of the tank,but still has the wiring connected. It's been years and trying to remember where the sensor should be pushed back into the tanks rubber groument,so that the float would hang down or would swing upward. Try it both ways while holding it and keeping in mind the hinged float will be trying to float upward with a full tank. Squirrel Crusher
Old Sep 1, 2011 | 05:40 PM
Well, gfolino signed in last week and made all his visits the same day and none since, I guess we will never know.
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
sittininthesun
Aug 24, 2015 10:47 AM
chturner
Jul 24, 2015 04:47 PM
Zoodust
Jul 16, 2015 06:17 PM
