need advice please
Old Sep 10, 2011 | 08:49 AM
phill's Avatar
Default need advice please
hi,new member here,i have brought a 05 crossfire 3.2 auto,i brought it knowing it had a problem with the torque converter,im just wondering if any one has come across this problem before and can confirm it is the converter,when the car is cold if you put it in gear it jumps forward,when it has been running for a while ur lucky to get any drive at all,when ticking over it sounds like a cement mixer going round,ive not drove it as ive been told it will lock up,any advice is very welcome,also any one no the best place to get a converter from,(will a mercedes one fit ),
Old Sep 10, 2011 | 12:13 PM
waldig's Avatar
Talking Re: need advice please
85% you are low on tranny fluid, do a search on tranny and measure the level in the pan, I designed a cheap wire tie to do the job. Use correct fluid. Woody
Old Sep 10, 2011 | 12:25 PM
phill's Avatar
Default Re: need advice please
The box and coverter is out, I removed the tube on the right hand side and the oil is level with the hole ( hope this makes scenes).
franklindm
Mar 14, 2020 12:23 PM
HOT FIYA
May 31, 2019 08:01 PM
PimpDaddy
Sep 29, 2016 11:55 PM
Selbyl
Sep 22, 2015 10:41 PM
Firebombbandit
Sep 3, 2015 06:42 PM
