What mods would you recommend for a budget of $5k?
Old Dec 24, 2011 | 03:51 PM
user 76087293's Avatar
Guest
Default What mods would you recommend for a budget of $5k?
Hello all,
I would like to mod my 2005 SRT-6 coupe but am a novice. I am fairly adept with tools so should be able to tackle most bolt-ons okay. Like the title says I have a budget of $5k. but I don't know if I should get the single or duel CAI, I don't know what crank, or sc pulley I should get, should I mess with exhaust, resonators or cats? Please help!
Regards,
AustinGSrider
Old Dec 24, 2011 | 05:03 PM
MikeR's Avatar
Default Re: What mods would you recommend for a budget of $5k?
1. Cold air intake..... Needswings single or double...(double is better and fits your budget)...
2. Crank pulley or SC pulley.... I personally like the 181 crank pulley... but the 65mm SC pulley is good and easier.....
3. Eurocharged ECU tune... no question
4. Resonator delete.... nice growl and drops about 25-30 pounds..
5. Wavetrac LSD....you won't blow up this rear diff!
6. Eurocharged TCU tune....????
7. Needwings modified intake plenums...
8. Needwings supercooler.....
9. Separated IC....
that should get you plenty of power..... brake upgrades would probably be next on your list....
dang... this almost sounds like my car.....
Old Dec 24, 2011 | 05:12 PM
Guest
Thanks Mike.......what is the difference between using the 181 crank pulley and the 185?
Old Dec 24, 2011 | 11:34 PM
TommyT's Avatar
Im local and could take you for a ride in mine.... you could do all the same mods I have for that money
Old Dec 25, 2011 | 12:13 AM
MikeR's Avatar
I chose the 181 over the 185 to leave a little margin.... at least in my mind....
Old Dec 30, 2011 | 11:33 PM
Guest
Thanks for all the responses and an especially big thanks to TommyT. I am well on my way. I have decided to do the following:
NeedsWings Aluminum Intake Manifolds
NeedsWings Cold Air Intake System Teflon Velocity Coated
NeedsWings Teflon/Thermal Coated Lower YPipe
Teflon Coated Valve Covers
NeedsWings Crossfire Oil Catch Can Kit
After this will be SC Pulley and Tune.
Apr 28, 2016 02:04 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
