Battery ran down
Old Jul 26, 2012 | 07:54 PM
Gary Hazelbaker's Avatar
Smile Battery ran down
I have a 2005 crossfire std. trans. Battery went dead while sitting with the key out and the Rest light ( the light on the button for recirculating air in the car ) on and the fan also on. I didn't think the fan would keep running with the key out. Why did the battery run down??
Old Jul 26, 2012 | 08:07 PM
Default Re: Battery ran down
Gary, how old is the battery? Not real sure if you had the key out, anything would be on...
Old Jul 26, 2012 | 08:22 PM
Battery is 2 mo. old. Key was out of car. Battery was dead. I put a battery charger on and I found that the Rest. light was on and the fan was blowing
Old Jul 26, 2012 | 08:28 PM
That is strange. I know there are some components that will stay on for a short time once the key is off, but not heard of that one.....I have to move one of mine, I will see what one of mine does....but I don't remember the fan continuing...
Old Jul 26, 2012 | 08:46 PM
I"v never used that REST function - never gets cold enough in GA to use it!
I was thinking "REST" timed out in about 1/2/ hour. If it does NOT time out, and you let it run long enough, yes, you will have a dead battery. But I THOUGHT that the REST function automatically timed out!
This is an odd one. Are you SURE the alternator is charging? I know, silly question but fact is - we are not there to witness this!
I'd think the REST functions' current draw would be 3 to 8 amps. THat would mean a dead battery, even if the battery is NEW and fullly charged, in probably less than 24 hours.
Old Jul 26, 2012 | 08:49 PM
it should have timed out....not sure why it didn't or if you may have left something else on and didn't realize it..... keep looking.... but I think we can rule out battery....for now...
Old Jul 26, 2012 | 10:26 PM
With the key out of the car. I can turn the radio on push the rest button ( the light will come on ) and turn the fan on and it will blow. Should any of this be happening with the key out of the car.
Old Jul 26, 2012 | 11:01 PM
MoparFreak69's Avatar
Yes, that is normal. The REST should shut itself off after 30 mins. or if the battery falls below a certain voltage.
Old Jul 28, 2012 | 08:37 AM
Maybe the battery is weak...but it should shut off...
blackpepper
Oct 4, 2017 06:09 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
o55ie18
Oct 5, 2015 05:50 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
Valk
Sep 17, 2015 11:43 AM
