Question about lifting my car.
Old Aug 31, 2012 | 10:13 PM
closer9's Avatar
Default Question about lifting my car.
Planning on changing diff oil, trans oil and flex discs in the near future. Looks like I can probably do rear diff on the garage floor, but my friend has a 2 post lift. There appear to be 4 jack points just inside the rockers. Am I correct in assuming lift pads can be set there? I remember reading about Solstices and Skys getting messed up, because they needed special blocks inserted before being put on a lift. Just want to make sure there aren't any gotchas before getting started...
Old Aug 31, 2012 | 10:23 PM
Default Re: Question about lifting my car.
I use small pieces of 2x6 lumber between the those jack points and the lift points, but yes those are the lift points...
Old Sep 1, 2012 | 10:20 AM
I have raised several Crossfires by the 4 jacking pads - never a problem.
Old Sep 1, 2012 | 11:21 PM
closer9's Avatar
Thanks! That's what I assumed, but you know what happens when you do...
Old Sep 14, 2012 | 12:04 PM
turbomar's Avatar
Jacking pics:
realglobe182
Aug 25, 2015 04:34 AM
waldig
Aug 14, 2015 01:10 PM
waldig
Aug 14, 2015 01:02 PM
Xfirenewbie
Aug 11, 2015 10:12 AM
velociabstract
Aug 7, 2015 01:30 PM
