installing pressure regulator valve
Old Sep 5, 2012 | 03:11 AM
fahed bassem's Avatar
Default installing pressure regulator valve
It has been said lean AF ratio can be solved by replacing the oem fuel filter with a free high flow fuel filter without regulator, along with an adjustable fuel pressure regulator valve. In this case one can go clockwise to increase pressure in the fuel lines, hense resulting in a richer mixure.
Question: How and where to install and wire them all?
thank you
Old Sep 5, 2012 | 06:41 AM
waldig's Avatar
Talking Re: installing pressure regulator valve
Contact Rob, he has kitted this approach that I first investigated, there are several write-ups in my posts,. I even went to 80 psi at the rail, pig rich 9:1..Woody Been there.
sittininthesun
Aug 24, 2015 10:47 AM
umpqua rafter
Aug 24, 2015 09:06 AM
Jul 29, 2015 06:13 PM
bdh
Jul 9, 2015 09:40 AM
