rpm limit increase problem
Old Sep 29, 2012 | 05:42 AM
fahed bassem's Avatar
Default rpm limit increase problem
was any body able to increase the limit of the rpm?
originally set to 6250rpm.
i already installed a tcu tune from eurocharged, which promised an rpm limit rase.
but this did not happen.
the car now cutts off with a loud noise, then shifts after that at 6250rpm.
this is making me much slower.
i thought it is an ecu problem, i installed a viezu tune (from england) to just raise the rpm.
nothing happened, the car still shifts after lound cutoff at 6250.
note before tcu tune from eurocharged the car shifts smoothly at 6250 rpm without cutoff.
thank you
Old Sep 29, 2012 | 12:11 PM
dtinker's Avatar
Default Re: rpm limit increase problem
Call Jerry or Adam at Eurocharged and get it back in to check out, you have something wrong.
Old Sep 29, 2012 | 12:40 PM
I already contacted jerry, and this is a copy of what he said.
By the way my car is a 2005 srt6, moded with 485 whp with a 50 shot nos.
Jerry ThorntonAdd to contacts
To bassem fahed
From:Jerry Thornton (jerry@eurocharged.com)Sent:Thursday, July 05, 2012 4:17:13 PMTo: bassem fahed (fahedbassem@hotmail.com)
.ExternalClass .ecxshape{;}.ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal{margin-bottom:.0001pt;font-size:12.0pt;font-family:"Times New Roman","serif";}.ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink{color:blue;text-decoration:underline;}.ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed{colorurple;text-decoration:underline;}.ExternalClass p{margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman","serif";}.ExternalClass p.ecxMsoAcetate, .ExternalClass li.ecxMsoAcetate, .ExternalClass div.ecxMsoAcetate{margin-bottom:.0001pt;font-size:8.0pt;font-family:"Tahoma","sans-serif";}.ExternalClass span.ecxEmailStyle18{font-family:"Calibri","sans-serif";color:#1F497D;}.ExternalClass span.ecxBalloonTextChar{font-family:"Tahoma","sans-serif";}.ExternalClass .ecxMsoChpDefault{font-size:10.0pt;}@page WordSection1{size:8.5in 11.0in;}.ExternalClass div.ecxWordSection1{page:WordSection1;}Yes, he did. Some versions of the original software will not allow for a 6500 RPM shift.
I’m still working on it now, so please hang tight while we test the new version.
Thanks,
Jerry Thornton
Eurocharged Performance
www.eurocharged.com
(281) 398-9700 - Office
(312) 446-6326 (312) 446-6326 - Cell
***Please note that Eurocharged has a new mailing address. As of 2/24/2012, our offices have moved to 221 Baker Road – Building E1 – Houston, TX 77094
Old Sep 29, 2012 | 02:14 PM
exshankerz's Avatar
I had mine eurocharged tuned and it revs max out as much as I want 7 and a half if I dare... That's weird I have a manual n/a bit could be a different setup with the ecu on auto srts , isn't it best to change around 6k anyway I was reading a few things and the torque drops and hp extra at those revs , guessing mabye not with noss and f/i
Old Sep 29, 2012 | 02:16 PM
exshankerz's Avatar
Sorry on my phone auto correcting and adding words I don't want!
Old Oct 1, 2012 | 12:47 PM
ckeck out this, it seams these guys have eurocharged TCU tune problems too.
hitting rev limiter after tcu tune - MBWorld.org Forums
Old Oct 2, 2012 | 01:50 PM
this is a sample what the guys on mb world forum, are saying.
I was wonder if anyone has had a problem with hitting the rev limiter after having a tcu tune. Not realy sure if its the rev limiter or torque limiter. Right before every shift under wot trottle the car almost pauses before shifting. I have s/c pulley, and ecu tune
I was wonder if anyone has had a problem with hitting the rev limiter after having a tcu tune. Not realy sure if its the rev limiter or torque limiter. Right before every shift under wot trottle the car almost pauses before shifting. I have s/c pulley, and ecu tune.
I have it and I was hoping someone on this forum would have it fixed by now so the same could be done to my car.
Yes, this also happens to me and a few other members on the forums.
I was told by Eurocharged that I was hitting a torque limiter. It would be good if they could give more info on this, but so far that's all I know.
I'm 320 Dreamer, wouldn't Eurocharged have already figured something out if this was a problem? I know your suggestion is only trying to help but I mean we bought a product, and now we have to do R&D to figure out if it's beneficial?
This doesn't sound right...not sure if there is a fix for it so I just usually shift before 6.5k to avoid hitting this limiter
I really hope the problem gets resolved as I also experience the same thing. I don't drive my car much so it hasn't bothered me too much. Do your 265s rub at all? I contemplated getting 265s but went with 255s instead
They just recieved my tcu today im not sure exactly whats going to be done to it but I mentioned to them about going back to the original shift points or ajusting the torque limiters. I havent ran my car car at the track yet since all of my upgrades, but knowing my car is going to hit the rev limiter between shifts isnt going to give me a very good e.t. If for some reason they cant figure it out im going to have buy another factory tcu. Yea, it bugs me that bad
I gotta think Eurocharged can at least restore the TCU to stock settings. I'd be very surprised if they can't.
bbsrt6
Feb 16, 2019 12:39 PM
Hoppy
Dec 7, 2018 07:36 AM
xzmilan
Jul 22, 2015 10:40 AM
Beeker
Jul 20, 2015 03:46 PM
Brandonky81
Jul 11, 2015 07:36 PM
