Spoiler light flashing.
Old Mar 10, 2014 | 01:13 PM
paul999's Avatar
Default Re: Spoiler light flashing. FIXED!!!!
I have had the issue of the spoiler light flashing for months now, tried all the usual things, but was convinced that nothing specific was wrong, as in if I reset the car (by disconnecting the battery and reconnecting it) everything works for about 10 mins, IE the roof went up and down, spoiler went up and down, then the flashing light came back again and the roof wouldn't move, or the spoiler.
Took the car to Mercedes who charged £300 to tell me they couldn't find the fault!, tried a few of the suggestions here, still no fix.
Sent the ecu to a specialist, no fault found.
In desperation I took the ECU out, and the small unit next to the ECU (body control module I think?) and removed every plug, fuse etc, and cleaned all 50-60 pins.
I found one pin on the small white connector (first plug from the front on the bcm) had slight corrosion, and was tracing to an adjacent pin.
Cleaned it up, - put it all back - Light now off!. Roof and spoiler works fine! I have tried to re create the problem, engine on and off, roof up and down, spoiler up and down, open boot, close boot, etc etc,
So far all good news! Total cost to fix - zero! So, as they say, try the simple things first!
Hope this helps anyone else who gets the flashing light!
Old Mar 11, 2014 | 06:25 PM
Thanks for sharing your findings with this problem.
Later,
Old Apr 14, 2014 | 10:25 AM
THE BBC's Avatar
Default Re: Spoiler would not go down manually after being manually raised.
Red light on switch would lite then go off. Depressing switch would not lower spoiler. Did battery reset spoiler still not going down. Found I had not latched the convertible top down completely. Latch it do all the way, spoiler goes down !!!
Old Jan 17, 2015 | 05:25 PM
BobG's Avatar
Had the "spoiler raised / blinking red light on switch / spoiler would not retract" problem last night.
I decided to try cleaning the latch first with compressed air. (WD-40 might also work.)
After cleaning and re-latching the hatch I was able to retract the spoiler via the switch.
I cannot confirm that cleaning resolved the problem, perhaps closing the hatch yet again played a role, but others in this situation should try cleaning first.
pioneer4x4
Jul 1, 2021 10:56 AM
wootto
U.K.
Aug 16, 2020 07:55 PM
pioneer4x4
Mar 25, 2019 10:35 AM
Hoppy
Dec 7, 2018 07:36 AM
northwest_crossfire
May 30, 2016 05:19 PM
