Spoiler Won't stay down
Old Nov 6, 2013 | 12:33 AM
Selbyl's Avatar
Default Re: Spoiler Won't stay down
Originally Posted by J-Walk
This is going to be an "out in left field" question, but do you have the Nav Radio? I have this problem as well. The solution for me is to put the nav cd in and let it load. Happens randomly.
My car came stock with Nav but I've had an aftermarket head unit for over a year now. Also I don't have the discs. My stock one stopped reading CDs so I went to a new unit, it's still sitting in a closet though. Good thing I didn't try to sell it yet.
Old Nov 18, 2013 | 06:34 AM
Selbyl's Avatar
Still having the issue, no speed sensor codes, and it's not a problem with the trunk latch. I'm thinking it's a problem with the switch. How does this switch work to control the motor?
Old Nov 18, 2013 | 06:58 AM
from the service manual :
Old Dec 14, 2013 | 02:04 PM
boxdin's Avatar
12.6 volts is approx one volt below where it's supposed to be. Should be approx 13.5- 13.8 when running. Our spoiler went up for no reason we thought but it turned out to be low voltage, a new batt solved the problem and it has not come back since. These cars need lots of elec power and strange things happen when power is low.
Old Dec 14, 2013 | 07:46 PM
Selbyl's Avatar
12.6V, not running. I haven't checked the running voltage in a while but normally it's around 13.8V. I also went to Napa to have a battery test done and they said it was good.
Old Dec 20, 2013 | 07:19 PM
Selbyl's Avatar
Default (Solved?) Spoiler Won't stay down
So problem solved possibly. Battery wasn't the issue from what I've found. I was taking apart the console and had to unplug the switch panel while working on my stereo. I plugged everything back in and made sure it all worked. Then when I was driving my car last night I heard the locks automatically kick in and the spoiler light wasn't blinking! I turned the car off and on a bunch of times and drove around. I haven't gotten it up to 65 yet to test that. But all seems normal again.
Old Dec 20, 2013 | 07:57 PM
boxdin's Avatar
What I said was low voltage upon retrospect could have been the BCM body control module beginning to go out. Later symptoms were power windows not working properly, and I now have that. Turns out its most likely the BCM, and I have learned that it is made with parts that wear out after a certain number of hours, hot cold cycles, and of course its very hot in the engine compartment.
I just removed my BCM to have it rebuilt w new components and w a lifetime warranty, I'll get it back next week.
The earliest of our cars are just now turning 10 yrs old and I think we are going to find out that the BCMs will need attention.
Lockhouse
Mar 20, 2024 04:50 PM
Reliableron
Oct 17, 2015 10:19 PM
atdavis2
Sep 21, 2015 01:25 PM
RacerXofFL
Sep 15, 2015 05:00 PM
davidc90
Sep 6, 2015 10:37 PM
